Release ASUS GT-AX11000 Pro Firmware version 3.0.0.6.102_34815 (2025/10/29)
fruitcornbread
Version 3.0.0.6.102_34815
62.21 MB
2025/10/29
- Enhanced system stability.
- Enhanced input validation and refactored legacy string handling routines to ensure robust memory management.
- Mitigated security risks in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
- Implemented comprehensive validation and expanded command filtering in the web history API.
- Strengthened input validation and directory handling in the VPN configuration upload interface.
- Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
ZIP SHA-256 : 0E437BC8315AEB4A4095538B7051B9F1D36E7160A04C8E9FDC1024ADA43F7996
FW SHA-256 : 1bfcaf271584e1c16548cc14db145b411c24efe9e96f34bafe5cfc91e99fe9c1
Download: https://dlcdnets.asus.com/pub/ASUS/...000_PRO_300610234815.zip?model=GT-AX11000 Pro
(You will need to copy the link and paste it in a browser for the link above to work.)
