fruitcornbread
Version 3.0.0.4.388_23917
74.72 MB
2025/10/07
Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment.
Security Enhancements
- Password Policy Upgrade – Minimum of 10 characters, including at least one letter, one digit, and one special character; disallows consecutive identical characters; hardens defense against brute-force attacks.
- HTTPS on 8443 – Management interface now served over TLS by default.
- UPnP Disabled – Universal Plug and Play starts in the off state for reduced surface exposure.
- AiCloud Authentication Hardening (CWE-287) – Added layered verification.
- Authentication Logic Refactor – Removed redundant code paths for a lean sign-in flow.
- Memory Safety Guard (CWE-476) – Introduced null-reference protections across critical services.
- Enhanced IPsec Parameter Validation – The existing input checks have been hardened.
- Data Exposure Mitigation (CWE-200) – Reinforced controls on sensitive pathways.
- Detailed Audit Trails – Expanded logging within the authentication module.
System Improvements
- Connection Stability – Core algorithms refined for steadier links.
- Scheduling Accuracy – Timed tasks execute reliably under PPPoE, PPTP and L2TP WAN modes.
- Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list
ZIP SHA-256 : FE52BCB7D8B9C380224BFA9D3AB42A292F16297F860A682368068EE0227FA321
FW SHA-256 : 96dc15e575b114b736d6a7cac05092e288d799ac4ca0016110544f1c4fe6c2ea
Download: https://dlcdnets.asus.com/pub/ASUS/...T_AXE11000_300438823917.zip?model=GT-AXE11000
rog.asus.com
74.72 MB
2025/10/07
System Improvements
ROG Rapture GT-AXE11000 | Gaming Networking|ROG - Republic of Gamers|ROG Global
Tri-Band Wifi 6E Gaming Router, Latest WiFi Standard, 6GHz Band, 10 Gigabit, 2.5G Gaming Port, VPN, Network Security, Mesh WiFi System, WiFi Coverage
