Solved ASUS GT-BE98 PRO High pings this makes no sense
cc666
I have my Asus GT-BE 98PRO router using the Cloudflare DNS servers. When I am on the Dashboard the ping averages 56ms. When I go to do a speed test in the Game Acceleration Internet speed test the result is a ping of 13.70. I think the ping reporting on the Dashboard in not correct. I also run speedtest with Okela on my computer and the pings are also low.
I noticed that this just started to happen with the 5/8 firmware 3.0.0.6.102_37839. Anyone else seeing this?
CC
I solved my problem, I had my modem Cat 6 in the 10G WAN. I switched the 2.5 G WAN input and my pings went from 65 to 22. I have a 1.5 GB connection so it made no sense to have the Modem connected at 10G. All good now
CC
