Asus N66U - Slow NZB downloads with Virgin - HTTP is ok though
bigup
So went and bought a N66u last night
set it up with virgin superhub (UK) in modem mode
all seems ok
but my nzbs are downloading at 2.5Mb/s instead of full 100MB/s
thought it was faulty so switched back to superhub in router mode and NZB/speedtest.net is full speed
so now back to Asus n66u and superhub in modem mode
tried a http download from: http://gamefiles.virginmedia.com/blueyondergames/demos/ and get full speed!
its only my nzbs are now throttled to about 2.5MB/s and speetest.net is 30Mb speed
when itried speedtest.net on superhub with lan cable i got 85Mb+ speeds
all above done locally on routers and not wireless
QOS is off, firewall on
have tried latest RMerlin's firmware and the latest offical firmware, still the same
ive gone through every option on the N66u and i cant seem to get this working, it is not traffic management as when i swap between them both superhub in router mode works at full speed straight away
using good quality Cat5e cable and have tried a few of them
thanks
just an idea of how my setup is like:
SuperHub Modem Mode> N66U > Netgear 16 port GS116 GB Switch> wired home network
with the above setup i get 2.5MB/s max speed downloads from NZB and Speedtest but 100MB/s speeds using HTTP downloads
if i take the N66U out of the equation
SuperHub Modem/Router Mode> Netgear 16 port GS116 GB Switch> wired home network
i get full 100MB/s speeds on everything (LAN based), rest of infrastructure is the same and untouched
only thing i haven't down is clear NVRAM, you guys think this will help?
Do i need to turn QOS on?
just doing some tests
tried all different usenet ports and it looks like i HAVE to have QOS switched on for it to get to at least 8.0MB/s and using all 20 connections (astraweb)
this is with latest official firmware. not sure if this is a bug or not?
http still gives me 9.9MB/s so still not right but better than before
anyone have this issue?
I'm not sure whether this helps, but I have a very similar setup to you (although I've managed to avoid a shub for now) and don't have any issues.
PC -> Netgear 8 port switch -> N66u -> VM Modem
and I can dl from usenet (astra) @ 12.4MB/s no problem using 20 connections most of the time.
I'm using the stock Asus firmware and do not have QOS enabled.
Are you rebooting the shub inbetween switching between the n66u and the shub router? If not, that may be worth a try.
If you are, is it possible you are being assigned a diff external ip address on the shub (which astra may not like the switching between ip addresses) and only allows some of your connections to run?
think I cracked it, last night i had a brain wave
the Ethernet cable between n66u and upstairs 16 port gb switch is quite old, checked it out and it was just Cat5 :eek:
luckily i have another cable which is cat5e running in parallel so just used that and now astraweb is coming up 12.4MB/s
seems like the N66U is very picky with the cables it uses as the superhub used to get me about 10MB/S with the Cat5 cable
anyway, will monitor it but so far so good
ahh, that makes sense! I think cat5 is 100mbit vs cat5e gigabit, which would explain only getting the 10MB/s using the shub.
It's the same I had with my old netgear router which only had 100mbit ports, that would only give around 9.6MB/s but as soon as I switched to the Asus with gigabit ports, got the full 12.4MB/s.
