ASUS Routers and Loss of 2.4 GHz Band
DGB1483
Hi All:
I just purchased as RT-AX88U router. Within a day of installation I lost the 2.4 GHz band. I was not able to find it's SSID and all of my 2.4 GHz band devices stopped functioning. By re-booting the router I was able to restore 2.4 GHz service. The 5 GHz band continued to function normally.
The odd thing is that I have had two other routers do the same thing to me in recent weeks: my old RT-AC3100 and a new Netgear RAX80.
Does anyone have any ideas as to what might be going on?
Don Barar
Hi All:
Don Barar
Welcome
There are some electrical devices affect the frequency of 2.4, such as the microwave and screens for the farthest from the router and placed in a place above the level of land as well as possible to change the channel to 1 or 6 or 11, and then proved on the best.
Channel 6 was selected and 2.4 GHz radio band was still lost. 5 GHx worked normally. I had to re-boot to restore 2.4 GHz service.
RT-AX88U is in the same location as RT-AC3100 and both lose the 2.4 GHz band. This is a new phenomena. The RT-AC3100 never lost the 2.4 GHz band until several months ago. I replaced the AC3100 because I though that I was having a hardware problem. But this does not seem to be the case.
Besides, I can see having difficulty connecting to devices because of something interposed between the router and the device. But to lose the radio all together and not even be able to access devices that are adjacent to router seems to be highly improbable of radio interference. The radio just stops working.
Anyone else have an idea as to what might be happening.
Don
Look like 2.4 GHz interference from other devices. Try to test your routers at other places. See 2.4 GHz band is still dropping or not.
Hi Jayce:
This is not an interference issue. It is complete loss of the 2.4 GHz radio. The only way to restore service is to re-boot the router. If it was an interference issue, re-booting the router would not immediately solve the problem.
Don
Hi Jayce:
Don
I was having this issue with my RT-AC87U on 5G band many time. But that loss of 5G band never stayed lost more than few minutes. Never had to reboot for that cause to bring it back.
Hi Jayce:
Don
I have no idea then since all 3 of the routers have the same issue.
Kind of late to the party, but I experienced the same thing with an AX88u, now experiencing the same thing with a RE-BE88u.
It's exactly the same behaviour explained here by other users.
You've necroposted a almost six year old discussion. You might want to start a new topic. It would be helpful if you provided more information about your WiFi settings, if there is anything in the router log indicating an issue, and what firmware you are running.
