forum_dyskusyjne
I am asking for help because I do not know what is causing the problem.
All routers was restarted to factory settings, network always have built from "scratch" - after factory reset.
Setting:
Parental control
QOS
etc. are OFF
Asus has an open support request...
Link to the video showing the measurements.
Part 1.
AIMESH routers: RT-AC59U V2 and RT-AC58U V3.
About every 72 hours, the connection speed periodically drops to 100Mb on WiFi and LAN .
Modem ISP LAN => WAN Asus.
Helps:
1. Removing and connecting the WAN cable to the ASUS router RT-AC59U V2.
2. Restart your ASUS router.
Part 2. Test.
I put the TpLink C6 router between the ISP modem and the Asus router.
Modem ISP LAN => WAN TpLink LAN => WAN Asus.
The TpLink router has no speed drop.
Asus routers have a cyclical decrease in WiFi, LAN speed.
I tested both routers, behaviour routers is always the same.
Helps:
1. Removing and connecting the WAN cable to the ASUS router RT-AC59U V2 or RT-AC53U V3
ISP LAN modem - has the correct speed.
Film:
IMESH (00:00 - 04:00)
WiFi speed test (100Mb drop).
Removing and inserting the WAN cable.
Correct speed.
TEST 1 (04:00 - 10:48)
WiFi TpLink test - correct.
Asus WiFi Test - Down to 100Mb.
Asus LAN Test - Down to 100Mb.
TpLink LAN test - correct.
TEST 2 (10:48 - 17:37)
Asus WiFi test - correct.
Setting:
Parental control
QOS
etc. are OFF
Part 1.
Helps:
Part 2. Test.
Helps:
Film:
Correct speed.
