Asus RT -Ac 58U after upgrade to firmware:3.0.0.4.382_51939
adam1
Hello and welcome. I am new and my knowledge in this subject is small
From several days I have had the same error in loop. looks below
Jan 19 17:24:37 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:24:43 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:24:53 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:24:59 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:25:06 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:25:12 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:25:30 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:26:00 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:26:06 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:26:13 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:26:27 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:26:34 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:26:48 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:26:54 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:27:03 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:27:09 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:27:15 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:27:41 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:27:54 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:28:14 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:29:00 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:29:12 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:29:18 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:29:24 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:29:30 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:29:37 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:29:46 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:30:00 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:30:06 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:30:12 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:30:18 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:30:24 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:30:33 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:30:39 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:30:45 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:30:51 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:31:04 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:31:10 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:31:16 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:31:22 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 19 17:31:28 dnsmasq[14322]: Maximum number of concurrent DNS queries reached (max: 150)
Dnsmasq.conf file looks
admin2@RT-AC58U:/tmp/etc# cat dnsmasq.conf
pid-file=/var/run/dnsmasq.pid
user=admin2
bind-dynamic
interface=br0
interface=pptp*
no-dhcp-interface=pptp*
no-resolv
servers-file=/tmp/resolv.dnsmasq
no-poll
no-negcache
cache-size=1500
min-port=4096
dhcp-range=lan,192.168.1.2,192.168.1.254,255.255.255.0,86400s
dhcp-option=lan,3,192.168.1.1
dhcp-option=lan,252,"\n"
dhcp-authoritative
address=/findasus.local/192.168.1.1
I need Help, what should I do?
Is there a way to modify dnsmasq.conf on stock firmware?
I would change to this:
cache-size=2500
I would delete this:
no-negcache
No.
cache-size=2500
That error has nothing to do with caching. In fact when a few of us tested this a few years ago, nobody ever reported an instance where the 1500 entries cache was too small.
This error indicates that something on his network is trying to generate over 150 *concurrent* dns queries. Could be a misbehaving client, could be a problem with the upstream DNS causing requests to pile up, could be a software generating an abnormal number of concurrent requests (web server log analyzer doing reverse lookups, for example).
No.
I agree, but to really get to the bottom of this, one would need to tcpdump on the router filtering for DNS, transfer the capture file, bring it up in something like Wireshark and analyze the output. Stock firmware probably does not provide a way to tcpdump.
No need for that. Just stop dnsmasq, enable query logging, and manually launch dnsmasq.
I changed cache-size=2500 with diffrent values and nothing solved the problem
The same with add dns-forward-max=<queries>
Just stop dnsmasq, enable query logging, and manually launch dnsmasq"
IT sound interesting but how to stop dsnmasq and enable query logging? Do somebody write commands, please?
My guess is:
Add the following lines to /etc/dnsmasq.conf:
log-async=25
log-queries=extra
log-facility=/opt/var/log/dnsmasq.log
Restart dnsmasq:
service restart_dnsmasq
Or you could just disconnect each of your clients one by one until you find the device that is spamming the DNS server.
Restart dnsmasq:
That will cause the firmware to overwrite it. You have to manually kill it (killall dnsmasq), then run it (dnsmasq --log-async).
First I used
admin2@RT-AC58U:/tmp/etc# killall dnsmasq
admin2@RT-AC58U:/tmp/etc# dnsmasq --log-async
Replay from log
Jan 20 16:41:02 rc_service: service 5573:notify_rc restart_dnsmasq
Jan 20 16:41:02 dnsmasq[5576]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 20 16:41:08 dnsmasq[5576]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 20 16:42:06 dnsmasq[5576]: Maximum number of concurrent DNS queries reached (max: 150)
Jan 20 16:42:54 dnsmasq[5576]: Maximum number of concurrent DNS queries reached (max: 150)
Then I read dsnmasq.conf
user=admin2
bind-dynamic
interface=br0
interface=pptp*
no-resolv
no-poll
no-negcache
cache-size=1500
min-port=4096
dhcp-authoritative
and add lines
admin2@RT-AC58U:/tmp/etc# vi dnsmasq.conf
user=admin2
bind-dynamic
interface=br0
interface=pptp*
no-resolv
no-poll
no-negcache
cache-size=1500
min-port=4096
dhcp-authoritative
log-async=25
log-queries=extra
esc
:wq
and restart
admin2@RT-AC58U:/tmp/etc# service restart_dnsmasq
Done.
and the same like above
Did I use correctly the commands?
Why after save dnsmasq.conf with new lines and restart it the File has the same settings and lines. Should it have got a new lines? I suppose "yes
OK I used command
dnsmasq --no-daemon --log-queries --log-facility=/var/log/dnsmasq.log
and I know just now, what device is spamming:D
Now I have to blocked it
Amazing, it stopped completely.
I have nothing replay in log but router it is often lose connection
I need to test it yet
Where do I find the logs files for the router and all run daemons ?
