ASUS RT-AC3100 Firmware 3.0.0.4.385.20630
SwampKracker
38.13 MBytes
Security update
- Fixed CVE-2020-12695 (CallStranger)
- Fixed Reflected XSS vulnerability.
- Fixed Directory traversal vulnerability.
- Fixed CVE-2017-15653.
The update server transport layer security was upgraded and the old protocol was removed.
If your router firmware version is lower than 3.0.0.4.384.81116, please refer to the "Update Manually" section in https://www.asus.com/support/FAQ/1008000 to update the firmware
Please unzip the firmware file first then check the MD5 code.
MD5: 7477ec9a24b147ec027f2e55edd725c1
https://www.asus.com/us/Networking/RT-AC3100/HelpDesk_Download/
Smokindog
Updated both AC3100's I have. This time the GUI found the firmware on the net so no manual process. The one in AP mode completed and rebooted itself. Again, my main node ended with a message to manually reboot. Just a warning for those who may consider a remote update with no one to perform the final reboot.
Herbie Greenfield
Thanks so much. How has stability and performance been on the latest firmware version 3.0.0.4.385.20630 ?
FYI: I also run two AC3100, with one as Main router and the other as AiMesh AP, with wired backhaul.
Smokindog
Stability/performance has been good on both the main and the AP node. I do NOT use AiMesh, I do not see any benefits and only limitations using AIMesh if you've got a wired backhaul available.
