Asus RT-AC3200 forgets port forwards
JimBoCA
My Asus RT-AC3200 keeps forgetting the port forwards. I am running Asus firmeware 3.0.0.4.380_3479. I enter a couple, then add another one and all get removed. Also, some other config changes caused all 8 of mine to disappear, now I can't seem to get them to stick anymore. Anyone every seen this?
Seems to be a rash of this lately.....see
http://www.snbforums.com/threads/asuswrt-merlin-380-59-ac68u-port-fwd-apply-fail.33895/#post-273328
EDIT: I forget whether the ASUS OEM firmware has a Tools page. If not, telnet to the router and enter
nvram show | grep bytes
to see your used nvram
Thanks for the pointer, I searched this subforum but not others. I'll take a look.
Sent from my Nexus 6P using Tapatalk
Looks like I have a
little left, not sure what the norm is?
xxx@RT-AC3200:/tmp/home/root# nvram show | grep bytes
modem_bytes_data_save=1800
size: 65337 bytes (199 left)
modem_bytes_data_limit=0
modem_bytes_data_warning=0
And these are the top 20?
admin@RT-AC3200:/tmp/home/root# nvram show | awk '{print length(), $0 | "sort -n -r"}' | cut -d"=" -f 1 | head -n 20
3848 nmp_client_list
1520 client_info_tmp
1357 custom_clientlist
993 dhcp_staticlist
631 (ugly string removed)
624 sshd_dsskey
585 sshd_hostkey
476 qos_rulelist
444 webdav_smb_pc
367 rc_support
350 fb_comment
338 sshd_ecdsakey
125 fb_browserInfo
117 wps_env_buf
92 2:pa5ga2
92 2:pa5ga1
92 2:pa5ga0
92 0:pa5ga2
92 0:pa5ga1
92 0:pa5ga0
Guess it's just best to reset and start over, not happy about that, but oh well...
