Asus RT AC3200 Port Forwarding not working in dual WAN
Sylvain
Good Afternoon All,
I already post this but in the wrong forum sorry !
I replace my RTN66U working with Merlin firmware in dual WAN with a Asus RT AC3200 also running with Merlin Firmware. With my RTN66U my port forwarding was working perfectly in dual and non dual wan mode.
With the RT AC3200 in non dual WAN my port forwarding are working perfectly and all the port are redirected to the correct computer when accessing service from the internet, at the moment I activate the DUAL WAN, port forwarding stop working. I triple check my setup, my IP for both WAN and they are correct I choose load balacing as I had with the RT66NU !.
I really don`t know what am I doing wrong, I power up my old router and check all the setup for the dual wan and I have the same value in both Router !. Both port fowarding really don`t want to work properly with the RT AC3200, I can access the internet without problem everything seem`s to work perfectly, except port forwarding !
Do someone is aware of a problem with the dual wan mode of the Asus RT AC 3200 ?
Using AsusMerlin version 378.53
This was also not working with the original Asus Firmware on the RT AC3200 !
Best Regards,
Sylvain
Good Morning Everyone,
Give another try this morning, and recheck every paramaters, I can get out but my port forwarding are not working. The wan light is RED is it normal. Triple check the IP setting for both WAN and Ethernet lan 1, Ip setting are correct !
No one ever had this problem, I tried the search button and found nothing on the forum ! :0)
Best Regards,
Sylvain
