ASUS RT-AC5300 help in diagnosis
wrymer
Hello everyone
Hello everyone
I have an Asus RT-AC5300 router that has started to malfunction. Namely, after starting, the Power LED lights up.
Once I was able to upload a new firmware.
It is currently in a loop and is resetting.
Any hel needed.
Below is a listing from the serial port:
CFE version 7.14.131.1608 (r589038) based on BBP 1.0.37 for BCM947XX (32bit,SP,)
Build Date: Thu Oct 22 17:53:52 CST 2015 (chengche@ubuntu)
Copyright (C) 2000-2008 Broadcom Corporation.
Init Arena
Init Devs.
Boot partition size = 262144(0x40000)
DDR Clock: 800 MHz
Info: DDR frequency set from clkfreq=1400,*800*
et2: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.1608 (r589038)
CPU type 0x0: 1400MHz
Tot mem: 524288 KBytes
CFE mem: 0x00F00000 - 0x017A7AE8 (9075432)
Data: 0x00F500A8 - 0x00F505E8 (1344)
BSS: 0x00F505F8 - 0x00FA5AE8 (349424)
Heap: 0x00FA5AE8 - 0x017A5AE8 (8388608)
Stack: 0x017A5AE8 - 0x017A7AE8 (8192)
Text: 0x00F00000 - 0x00F46540 (288064)
Device eth0: hwaddr 70-4D-7B-95-C0-D0, ipaddr 192.168.1.1, mask 255.255.255.0
gateway not set, nameserver not set
Null Rescue Flag.
boot the image...
go load
Loader:raw Filesys:tftp Dev:eth0 File:: Options:(null)
Loading: TFTP Server.
..tftp retry wait 0
Failed.
Could not load :: Timeout occured
Loader:raw Filesys:raw Dev:nflash0.os File: Options:(null)
Loading: .... 4453056 bytes read
Entry at 0x00008000
Closing network.
Starting program at 0x00008000
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117) is a 16550
brd: module loaded
loop: module loaded
pflash: found no supported devices
bcmsflash: found no supported devices
Boot partition size = 524288(0x80000)
lookup_nflash_rootfs_offset: offset = 0x200000
nflash: squash filesystem with lzma found at block 29
Creating 4 MTD partitions on "nflash":
0x000000000000-0x000000080000 : "boot"
0x000000080000-0x000000200000 : "nvram"
0x000000200000-0x000004000000 : "linux"
0x0000003be6dc-0x000004000000 : "rootfs"
PPP generic driver version 2.4.2
PPP MPPE Compression module registered
NET: Registered protocol family 24
PPTP driver version 0.8.5
=== PPTP init ===
Pid: 1, comm: preinit
CPU: 0 Tainted: P (2.6.36.4brcmarm #1)
PC is at 0x2abafb9c
LR is at 0x2abb4c80
pc : [<2abafb9c>] lr : [<2abb4c80>] psr: 80000010
sp : 7ec38ff8 ip : 2abd4d60 fp : 00000000
r10: 6e616863 r9 : 00000001 r8 : 000013fa
r7 : 7ec3b078 r6 : 7ec3c2ec r5 : 7ec3dffc r4 : 2abc80d9
# wr3 : 00000000 r2 : 7ec3aff8 r1 : 0000000a r0 : 00000000
andFlags: Nzcv IRQs on FIQs on Mode USER_32 ISA ARM Segment user
uckControl: 10c53c7d Table: 5fb0c04a DAC: 00000015
: Got LANKernel panic - not syncing: Attempted to kill init!
(-1[<8005727c>] (unwind_backtrace+0x0/0xf8) from [<8031b2e4>] (panic+0x74/0x1a0)
) i[<8031b2e4>] (panic+0x74/0x1a0) from [<8007b8e8>] (do_exit+0x5cc/0x674)
nfo[<8007b8e8>] (do_exit+0x5cc/0x674) from [<8007bbec>] (do_group_exit+0x3c/0xbc)
rma[<8007bbec>] (do_group_exit+0x3c/0xbc) from [<80086434>] (get_signal_to_deliver+0x28c/0x3d4)
tio[<80086434>] (get_signal_to_deliver+0x28c/0x3d4) from [<800536a8>] (do_signal+0x54/0x5cc)
[<800536a8>] (do_signal+0x54/0x5cc) from [<80054154>] (do_notify_resume+0x50/0x5c)
wa[<80054154>] (do_notify_resume+0x50/0x5c) from [<80050d78>] (work_pending+0x24/0x28)
nduRebooting in 3 seconds..
CPU1: stopping
[<8005727c>] (unwind_backtrace+0x0/0xf8) from [<80050334>] (do_IPI+0x114/0x154)
[<80050334>] (do_IPI+0x114/0x154) from [<803e25e0>] (__irq_svc+0x60/0x138)
Exception stack(0x9f023d38 to 0x9f023d80)
3d20: 9fa89cc0 a0000013
3d40: 00000000 00000000 9f022000 9dcbee00 9f023e70 9f022000 9dcbec00 00000070
3d60: 00000000 00000070 9fa89cbc 9f023d80 8022669c 8031de4c 60000013 ffffffff
[<803e25e0>] (__irq_svc+0x60/0x138) from [<8031de4c>] (_raw_spin_unlock_irqrestore+0x18/0x40)
[<8031de4c>] (_raw_spin_unlock_irqrestore+0x18/0x40) from [<8022669c>] (sock_def_readable+0x50/0xac)
[<8022669c>] (sock_def_readable+0x50/0xac) from [<802c1308>] (unix_dgram_sendmsg+0x4f0/0x5bc)
[<802c1308>] (unix_dgram_sendmsg+0x4f0/0x5bc) from [<8022276c>] (sock_sendmsg+0x94/0xa8)
[<8022276c>] (sock_sendmsg+0x94/0xa8) from [<80224aa0>] (sys_sendto+0xb4/0xdc)
[<80224aa0>] (sys_sendto+0xb4/0xdc) from [<80224ae0>] (sys_send+0x18/0x20)
[<80224ae0>] (sys_send+0x18/0x20) from [<80050d20>] (ret_fast_syscall+0x0/0x30)
ck: delay 1 seconds before the first detect...
