Asus RT-AC5300 wierd problem with games
Atomic7431
I have the router in title, im on a 330/45 mb connection here in the uk.
I have the latest merlin version firmware 384.13, i have flashed this more than once and done complete factory wipe no restore of any kind.
Now me and my 2 kids play fps games a lot, for instance apex legends. So we can go on and play do really well (top 3 most games) that evening.
Get up the next day and we go on again and cant seem to hit a barn door, check ping looks ok 18ms max, usually aroun 7ms / 8ms.
Check bufferbloat its between ratings of B and A. So i think ok reboot router, then we game again. Suddenly were back to hitting everything and doing as we would normally, top 5 area with around 7 kills each, buffler bloat is usally an A after reboot.
Ive been monitoring this for a couple of weeks now, and been trying to get to the bottom of the issue for a lot longer, ive changed network cables, plugged everyone directly into the router and not the netgear switch. Seen the same result for a while, i even changed supplier and still see the same issues, i tried the provided fritzbox as well and it seems to not cope with the connection to well at all.
So what could this be? is it time for a new router with SQM, fq-codel and see how it goes or is it something else?
I was using the script on here by fresh jr at one point but its had no updates for a while either.
all help appreciated, do i need to find a new router?
ps. The router is about 2 years old now.
pps. also i had this kind of issue at my old address with this router but i just blamed the poor connection we had at the time, 5mb/0.7mb, but im wondering if router was at fault as well.
I wonder if the cpu cant handle the processing at fast speed of 300MB connection to well with the fq-codel (1.4 GHz dual-core processor)
Do i need a quad core cpu, reading around it may be the case......
