swordfishunter
Hi Guys,
I'm having lots of disconnects from my ac66U being used as a bridge. I'm no network engineer, and don't understand 99% of the logs that I see, although the router looks quite busy doing things. does any kind soul have any idea what is happening and how i can fix it?
Aug 1 08:00:14 syslogd started: BusyBox v1.20.2
Aug 1 08:00:14 kernel: klogd started: BusyBox v1.20.2 (2016-05-10 11:46:00 EDT)
Aug 1 08:00:14 kernel: start_kernel
Aug 1 08:00:14 kernel: Linux version 2.6.22.19 (root@asus) (gcc version 4.2.3) #1 Tue May 10 11:47:07 EDT 2016
Aug 1 08:00:14 kernel: CPU revision is: 00019749
Aug 1 08:00:14 kernel: Found an ST compatible serial flash with 32 64KB blocks; total size 2MB
Aug 1 08:00:14 kernel: Determined physical RAM map:
Aug 1 08:00:14 kernel: memory: 07fff000 @ 00000000 (usable)
Aug 1 08:00:14 kernel: memory: 08000000 @ 87fff000 (usable)
Aug 1 08:00:14 kernel: Built 1 zonelists. Total pages: 585216
Aug 1 08:00:14 kernel: Kernel command line: root=/dev/mtdblock3 console=ttyS0,115200 init=/sbin/preinit
Aug 1 08:00:14 kernel: Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Aug 1 08:00:14 kernel: Primary data cache 32kB, 4-way, linesize 32 bytes.
Aug 1 08:00:14 kernel: Synthesized TLB refill handler (20 instructions).
Aug 1 08:00:14 kernel: Synthesized TLB load handler fastpath (32 instructions).
Aug 1 08:00:14 kernel: Synthesized TLB store handler fastpath (32 instructions).
Aug 1 08:00:14 kernel: Synthesized TLB modify handler fastpath (31 instructions).
Aug 1 08:00:14 kernel: PID hash table entries: 2048 (order: 11, 8192 bytes)
Aug 1 08:00:14 kernel: CPU: BCM5300 rev 1 pkg 0 at 600 MHz
Aug 1 08:00:14 kernel: Using 300.000 MHz high precision timer.
Aug 1 08:00:14 kernel: console [ttyS0] enabled
Aug 1 08:00:14 kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Aug 1 08:00:14 kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Aug 1 08:00:14 kernel: Memory: 238352k/131068k available (2668k kernel code, 22808k reserved, 532k data, 200k init, 131072k highmem)
Aug 1 08:00:14 kernel: Mount-cache hash table entries: 512
Aug 1 08:00:14 kernel: NET: Registered protocol family 16
Aug 1 08:00:14 kernel: PCI: Initializing host
Aug 1 08:00:14 kernel: PCI: Reset RC
Aug 1 08:00:14 kernel: PCI: Fixing up bus 0
Aug 1 08:00:14 kernel: PCI/PCIe coreunit 0 is set to bus 1.
Aug 1 08:00:14 kernel: PCI: Fixing up bridge
Aug 1 08:00:14 kernel: PCI: Enabling device 0000:01:00.1 (0004 -> 0006)
Aug 1 08:00:14 kernel: PCI: Fixing up bus 1
Aug 1 08:00:14 kernel: PCI/PCIe coreunit 1 is set to bus 2.
Aug 1 08:00:14 kernel: PCI: Enabling device 0000:02:00.1 (0004 -> 0006)
Aug 1 08:00:14 kernel: PCI: Fixing up bus 2
Aug 1 08:00:14 kernel: NET: Registered protocol family 2
Aug 1 08:00:14 kernel: Time: MIPS clocksource has been installed.
Aug 1 08:00:14 kernel: IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
Aug 1 08:00:14 kernel: TCP established hash table entries: 16384 (order: 5, 131072 bytes)
Aug 1 08:00:14 kernel: TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
Aug 1 08:00:14 kernel: TCP: Hash tables configured (established 16384 bind 16384)
Aug 1 08:00:14 kernel: TCP reno registered
Aug 1 08:00:14 kernel: highmem bounce pool size: 64 pages
Aug 1 08:00:14 kernel: squashfs: version 3.2-r2 (2007/01/15) Phillip Lougher
Aug 1 08:00:14 kernel: io scheduler noop registered (default)
Aug 1 08:00:14 kernel: HDLC line discipline: version $Revision: 4.8 $, maxframe=4096
Aug 1 08:00:14 kernel: N_HDLC line discipline registered.
Aug 1 08:00:14 kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled
Aug 1 08:00:14 kernel: serial8250: ttyS0 at MMIO 0x0 (irq = 8) is a 16550A
Aug 1 08:00:14 kernel: serial8250: ttyS1 at MMIO 0x0 (irq = 8) is a 16550A
Aug 1 08:00:14 kernel: PPP generic driver version 2.4.2
Aug 1 08:00:14 kernel: MPPE/MPPC encryption/compression module registered
Aug 1 08:00:14 kernel: NET: Registered protocol family 24
Aug 1 08:00:14 kernel: PPPoL2TP kernel driver, V0.18.3
Aug 1 08:00:14 kernel: PPTP driver version 0.8.5
Aug 1 08:00:14 kernel: pflash: found no supported devices
Aug 1 08:00:14 kernel: Boot partition size = 262144(0x40000)
Aug 1 08:00:14 kernel: Creating 2 MTD partitions on "sflash":
Aug 1 08:00:14 kernel: 0x00000000-0x00040000 : "pmon"
Aug 1 08:00:14 kernel: 0x001f0000-0x00200000 : "nvram"
Aug 1 08:00:14 kernel: Found a Zentel NAND flash with 2048B pages or 128KB blocks; total size 128MB
Aug 1 08:00:14 kernel: lookup_nflash_rootfs_offset: offset = 0x0
Aug 1 08:00:14 kernel: nflash: squash filesystem with lzma found at block 9
Aug 1 08:00:14 kernel: Creating 2 MTD partitions on "nflash":
Aug 1 08:00:14 kernel: 0x00000000-0x02000000 : "linux"
Aug 1 08:00:14 kernel: 0x0013d54c-0x02000000 : "rootfs"
Aug 1 08:00:14 kernel: NAND device: Manufacturer ID: 0x92, Chip ID: 0xf1 (Zentel NAND 128MiB 3,3V 8-bit)
Aug 1 08:00:14 kernel: Creating 3 MTD partitions on "brcmnand":
Aug 1 08:00:14 kernel: 0x00000000-0x02000000 : "trx"
Aug 1 08:00:14 kernel: 0x02000000-0x04000000 : "jffs2"
Aug 1 08:00:14 kernel: 0x04000000-0x07f00000 : "brcmnand"
Aug 1 08:00:14 kernel: dev_nvram_init: _nvram_init
