Amin
Hello. I want use my Android smartphone (Modem-Mode) as backup WAN on USB 2.0 router port.
Router firmware - Merlin 378.56 (kernel 2.6.36.4brcmarm).
Phone - Highscreen Boost, Android 4.1.2 (kernel 3.4.0)
I activate "Modem mode" after USB-connect, but mobile device not apper in router interface.
When i connect smartphone to PC and activate modem-mode in smartphone, PC's NetworkManager (Linux Fedora 21) configured modem correctly.
How to use android 's devices in modem-mode as backup WAN on Asus router with Merlin firmware?
Thank you for any ideas.
12:49:49 Host kernel: usb 1-2: New USB device found, idVendor=05c6, idProduct=9026
12:49:49 Host kernel: usb 1-2: New USB device strings: Mfr=2, Product=3, SerialNumber=4
12:49:49 Host kernel: usb 1-2: Product: Android
12:49:49 Host kernel: usb 1-2: Manufacturer: Android
12:49:49 Host kernel: usb 1-2: SerialNumber: ****************
12:49:50 Host kernel: [72326.415774] qmi_wwan 1-2:1.3: cdc-wdm0: USB WDM device
12:49:50 Host kernel: [72326.415969] qmi_wwan 1-2:1.3 wwan0: register 'qmi_wwan' at usb-0000:03:00.0-2, WWAN/QMI device, d2:5e:22:de:15:12
12:49:50 Host kernel: [72326.416007] usbcore: registered new interface driver qmi_wwan
12:49:50 Host kernel: [72326.420465] usbcore: registered new interface driver uas
12:49:50 Host kernel: [72326.497869] qmi_wwan 1-2:1.3 wwp3s0u2i3: renamed from wwan0
12:49:50 Host kernel: usbcore: registered new interface driver cdc_wdm
12:49:52 Host ModemManager[780]: <info> Creating modem with plugin 'Generic' and '2' ports
12:49:52 Host ModemManager[780]: <info> Modem for device at '/sys/devices/pci0000:00/0000:00:1c.1/0000:03:00.0/usb1/1-2' successfully created
12:49:53 Host ModemManager[780]: <warn> couldn't load Supported Bands: 'Couldn't get band capabilities: QMI protocol error (71): 'InvalidQmiCommand''
12:49:53 Host ModemManager[780]: <info> Modem: state changed (unknown -> disabled)
12:49:53 Host NetworkManager[836]: <warn> (cdc-wdm0): failed to look up interface index
12:49:53 Host NetworkManager[836]: <info> (cdc-wdm0): modem state changed, 'disabled' --> 'enabling' (reason: user preference)
12:49:53 Host NetworkManager[836]: <info> (cdc-wdm0): new Broadband device (driver: 'qmi_wwan' ifindex: 0)
12:49:53 Host NetworkManager[836]: <info> (cdc-wdm0): exported as /org/freedesktop/NetworkManager/Devices/6
12:49:53 Host NetworkManager[836]: <info> (cdc-wdm0): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
12:49:53 Host NetworkManager[836]: <info> (cdc-wdm0): preparing device
12:49:53 Host NetworkManager[836]: <info> (cdc-wdm0): modem state 'enabling'
12:49:53 Host NetworkManager[836]: <info> (cdc-wdm0): device state change: unavailable -> disconnected (reason 'none') [20 30 0]
12:49:53 Host ModemManager[780]: <info> Modem /org/freedesktop/ModemManager1/Modem/0: state changed (disabled -> enabling)
12:49:54 Host ModemManager[780]: <info> Modem /org/freedesktop/ModemManager1/Modem/0: state changed (enabling -> disabled)
12:49:54 Host NetworkManager[836]: <info> (cdc-wdm0): modem state changed, 'enabling' --> 'disabled' (reason: unknown)
12:49:54 Host NetworkManager[836]: <warn> (cdc-wdm0) failed to enable modem: GDBus.Error
rg.freedesktop.libqmi.Error.Protocol.InvalidQmiCommand: Couldn't get serving system: QMI protocol error (71): 'InvalidQmiCommand'
12:50:02 Host kernel: [72338.466885] usbcore: registered new interface driver cdc_ether
12:50:02 Host kernel: usbcore: registered new interface driver cdc_ether
12:50:02 Host kernel: [72338.473393] rndis_host 1-2:1.0 usb0: register 'rndis_host' at usb-0000:03:00.0-2, RNDIS device, 12:59:e6:1b:85:ad
12:50:02 Host kernel: [72338.473424] usbcore: registered new interface driver rndis_host
12:50:02 Host kernel: rndis_host 1-2:1.0 usb0: register 'rndis_host' at usb-0000:03:00.0-2, RNDIS device, 12:59:e6:1b:85:ad
12:50:02 Host kernel: usbcore: registered new interface driver rndis_host
12:50:02 Host kernel: [72338.491218] rndis_host 1-2:1.0 enp3s0u2: renamed from usb0
12:50:02 Host kernel: rndis_host 1-2:1.0 enp3s0u2: renamed from usb0
12:50:02 Host NetworkManager[836]: <info> (enp3s0u2): carrier is OFF
12:50:02 Host NetworkManager[836]: <info> (enp3s0u2): new Ethernet device (driver: 'rndis_host' ifindex: 8)
12:50:02 Host NetworkManager[836]: <info> (enp3s0u2): exported as /org/freedesktop/NetworkManager/Devices/7
12:50:02 Host NetworkManager[836]: <info> (enp3s0u2): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
12:50:02 Host NetworkManager[836]: <info> (enp3s0u2): link connected
12:50:02 Host NetworkManager[836]: <info> (enp3s0u2): preparing device
12:50:02 Host NetworkManager[836]: <info> read connection 'Проводное соединение 1'
12:50:02 Host NetworkManager[836]: <info> (enp3s0u2): created default wired connection 'Проводное соединение 1'
12:50:02 Host NetworkManager[836]: <info> (enp3s0u2): device state change: unavailable -> disconnected (reason 'none') [20 30 0]
12:50:02 Host NetworkManager[836]: <info> Auto-activating connection 'Проводное соединение 1'.
12:50:02 Host NetworkManager[836]: <info> Activation (enp3s0u2) starting connection 'Проводное соединение 1'
12:50:02 Host NetworkManager[836]: <info> Activation (enp3s0u2) Stage 1 of 5 (Device Prepare) scheduled...
12:50:02 Host NetworkManager[836]: <info> Activation (enp3s0u2) Stage 1 of 5 (Device Prepare) started...
12:50:02 Host NetworkManager[836]: <info> (enp3s0u2): device state change: disconnected -> prepare (reason 'none') [30 40 0]
12:50:02 Host NetworkManager[836]: <info> Activation (enp3s0u2) Stage 2 of 5 (Device Configure) scheduled...
12:50:02 Host NetworkManager[836]: <info> Activation (enp3s0u2) Stage 1 of 5 (Device Prepare) complete.
12:50:02 Host NetworkManager[836]: <info> Activation (enp3s0u2) Stage 2 of 5 (Device Configure) starting...
12:50:02 Host NetworkManager[836]: <info> (enp3s0u2): device state change: prepare -> config (reason 'none') [40 50 0]
12:50:02 Host NetworkManager[836]: <info> Activation (enp3s0u2) Stage 2 of 5 (Device Configure) successful.
12:50:02 Host NetworkManager[836]: <info> Activation (enp3s0u2) Stage 3 of 5 (IP Configure Start) scheduled.
12:50:02 Host NetworkManager[836]: <info> Activation (enp3s0u2) Stage 2 of 5 (Device Configure) complete.
12:50:02 Host NetworkManager[836]: <info> Activation (enp3s0u2) Stage 3 of 5 (IP Configure Start) started...
12:50:02 Host NetworkManager[836]: <info> (enp3s0u2): device state change: config -> ip-config (reason 'none') [50 70 0]
12:50:02 Host NetworkManager[836]: <info> Activation (enp3s0u2) Beginning DHCPv4 transaction (timeout in 45 seconds)
12:50:02 Host NetworkManager[836]: <info> dhclient started with pid 23518
12:50:02 Host NetworkManager[836]: <info> Activation (enp3s0u2) Stage 3 of 5 (IP Configure Start) complete.
12:50:02 Host NetworkManager[836]: <info> (enp3s0u2): DHCPv4 state changed nbi -> preinit
12:50:02 Host dhclient[23518]: Created duid \000\001\000\001\036\017\315\312\022Y\346\033\205\255.
12:50:02 Host dhclient[23518]: DHCPDISCOVER on enp3s0u2 to 255.255.255.255 port 67 interval 3 (xid=0x3b957a)
12:50:03 Host avahi-daemon[781]: Registering new address record for fe80::1059:e6ff:fe1b:85ad on enp3s0u2.*.
12:50:04 Host ModemManager[780]: <warn> Couldn't find support for device at '/sys/devices/pci0000:00/0000:00:1c.1/0000:03:00.0/usb1/1-2': not supported by any plugin
12:50:05 Host dhclient[23518]: DHCPDISCOVER on enp3s0u2 to 255.255.255.255 port 67 interval 5 (xid=0x3b957a)
12:50:07 Host dhclient[23518]: DHCPREQUEST on enp3s0u2 to 255.255.255.255 port 67 (xid=0x3b957a)
12:50:07 Host dhclient[23518]: DHCPOFFER from 192.168.42.129
12:50:07 Host dhclient[23518]: DHCPACK from 192.168.42.129 (xid=0x3b957a)
12:50:07 Host NetworkManager[836]: <info> (enp3s0u2): DHCPv4 state changed preinit -> bound
12:50:07 Host NetworkManager[836]: <info> address 192.168.42.110
12:50:07 Host NetworkManager[836]: <info> plen 24 (255.255.255.0)
12:50:07 Host NetworkManager[836]: <info> gateway 192.168.42.129
12:50:07 Host NetworkManager[836]: <info> server identifier 192.168.42.129
12:50:07 Host NetworkManager[836]: <info> lease time 3600
12:50:07 Host NetworkManager[836]: <info> hostname 'Host'
12:50:07 Host NetworkManager[836]: <info> nameserver '192.168.42.129'
12:50:07 Host NetworkManager[836]: <info> Activation (enp3s0u2) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
12:50:07 Host NetworkManager[836]: <info> Activation (enp3s0u2) Stage 5 of 5 (IPv4 Commit) started...
12:50:07 Host avahi-daemon[781]: Joining mDNS multicast group on interface enp3s0u2.IPv4 with address 192.168.42.110.
12:50:07 Host avahi-daemon[781]: New relevant interface enp3s0u2.IPv4 for mDNS.
12:50:07 Host avahi-daemon[781]: Registering new address record for 192.168.42.110 on enp3s0u2.IPv4.
12:50:07 Host NetworkManager[836]: <info> (enp3s0u2): device state change: ip-config -> ip-check (reason 'none') [70 80 0]
12:50:07 Host NetworkManager[836]: <info> Activation (enp3s0u2) Stage 5 of 5 (IPv4 Commit) complete.
