beatles1312
Hello guys,
i have a ASUS RT-AC86U with Merlin 384.19 build. I've been struggling to get a stable connection with ExpressVPN for weeks. I setup the OpenVPN Client like with every other VPN Provider but i always getting disconnect after a few hours. Sometimes it's working for 2 hours and sometimes for 13 hours. In the System protcol i always get the following error:
Nov 20 07:44:25 ovpn-client2[9925]: RESOLVE: Cannot resolve host address: germany-frankfurt-1-ca-version-2.expressnetw.com:1195 (Temporary failure in name resolution)
Nov 20 07:44:25 ovpn-client2[9925]: Could not determine IPv4/IPv6 protocol
Nov 20 07:44:25 ovpn-client2[9925]: SIGUSR1[soft,init_instance] received, process restarting
Nov 20 07:44:25 ovpn-client2[9925]: Restart pause, 5 second(s)
Nov 20 07:44:30 ovpn-client2[9925]: WARNING: --ns-cert-type is DEPRECATED. Use --remote-cert-tls instead.
Nov 20 07:44:30 ovpn-client2[9925]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Nov 20 07:45:10 ovpn-client2[9925]: RESOLVE: Cannot resolve host address: germany-frankfurt-1-ca-version-2.expressnetw.com:1195 (Temporary failure in name resolution)
Nov 20 07:45:50 ovpn-client2[9925]: RESOLVE: Cannot resolve host address: germany-frankfurt-1-ca-version-2.expressnetw.com:1195 (Temporary failure in name resolution)
Nov 20 07:45:50 ovpn-client2[9925]: Could not determine IPv4/IPv6 protocol
Nov 20 07:45:50 ovpn-client2[9925]: SIGUSR1[soft,init_instance] received, process restarting
Nov 20 07:45:50 ovpn-client2[9925]: Restart pause, 5 second(s)
Then i'm switch the Off/On toggle in the OpenVPN Client and it getting connected again. It's working great again, but also only for a few hours, then the same error message.
With other VPN Service providers i never had any problems. I can get connected to NordVPN for weeks without any problem with the same setup.
This is the Custom Configuration:
fast-io
remote-random
pull
tls-client
ns-cert-type server
route-method exe
route-delay 2
tun-mtu 1500
fragment 1300
mssfix 1200
keysize 256
sndbuf 524288
rcvbuf 524288
The ExpressVPN Support can't help, so i'm trying here if anyone can help me with this issue
Thanks and have an nice day!
fast-io
remote-random
pull
tls-client
ns-cert-type server
route-method exe
route-delay 2
tun-mtu 1500
fragment 1300
mssfix 1200
keysize 256
sndbuf 524288
rcvbuf 524288
