ASUS RT-AC87U Can't Get Asuswrt-Merlin to work.
M_JC
I have an RT-AC87U and want to use Asuswrt-Merlin so that I can exclude some devices from my OpenVPN connection. I have flashed releases RT-AC87U_380.69_0 and RT-AC87U_380.68_4. Both are unstable the router constantly locks up and reboots. I have tried factory resets too for both release levels. When I flash back to the standard ASUS firmware RT-AC87U_3.0.0.4_380_7743-g2cf84e9 everything works perfectly. I don't see anyone else having this problem so it must be something that I am doing. Can anyone make any suggestions?
First "idea": Factory Reset AND Power Cycle (should always go together). :eek:
I recall some similar issues when I started with my first AC87U: I did a factory reset AND power cycle and then a minimal config to allow flashing AGAIN!
The dual flashing with another Factory Reset and Power Cycle did the trick for me. :cool:
Since then the two devices are rock solid (on .65 version).
Hi Joegreat,
Fast reply - thanks. Did as you said and have been up now for 10 minutes or so without crashing so looking good. Unfortunately I went down to the .65-4 version like you so I can't be certain that it is because of the version or the way of flashing it. I am not about to try to upgrade to a later version for a while now this is working.
Thanks again.
Martin
Hi Joegreat,
Thanks again.
Martin
Where you loading any saved configurations from the stock Asus Firmware?
You need to manually re-enter all your previous saved settings. Otherwise that can cause problems.
Sent from my ONEPLUS A3003 using Tapatalk
Hi djblade20354,
I tried all variations; even factory reset. I never got to set up my configuration as the router would reboot or freeze after a few seconds, never longer than a minute.
Been up on .65-4 for a few hours now. Got everything reconfigured. Working great but I don’t want to try a later version.
Is anyone running a version later than .65-4 on an RT AC87U?
Sure, .69 here. Up 4 1/2 days--I have a scheduled reboot every sunday.
You really should try .69 again. I haven't had reboot issues on any of the firmwares, but a lot of work has been done since .65, obviously.
