Release ASUS RT-AX59U Firmware version 3.0.0.4.388_33147
Volt
Version 3.0.0.4.388_33147
37.79 MB
2024/03/14
Bug fixes and functionality modifications:
  • Resolved IPTV interruptions during extended use.
  • Addressed Guest Network performance issues with active IPTV.
  • Fixed potential Aura RGB crash.
  • Added eXtra Long Range support for enhanced connectivity.
  • Rectified potential IPV6-related crashes.
  • Improved roaming efficiency for AiMesh nodes under weak signals.
  • Addressed router crashes during WireGuard setup.
  • Fixed abnormal activation status in the Gear Accelerator function UI
Please unzip the firmware file, and then verify the checksum.
SHA256: ba3c8069f1e5747fd9ea984c96926763265f36f26a49af1a8362d1d5676d6752
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX59U/FW_RT_AX59U_300438833147.zip?model=RT-AX59U
I'm UK based. I have updated to 33147 and can confirm (at least for me!) that it works. All upgraded smoothly and all devices reconnected and my AIMesh node eventually re-linked by itself. The router was still looking for 33144 so I had to manually download 33147 which adding even more confusion, has 33305 in the title!!
Phil.
