Release ASUS RT-AX86 Series(RT-AX86U/RT-AX86S) Firmware version 3.0.0.4.388_24401 (2025/10/20)
visortgw
Part of the Furniture
71.53 MB, 2025/10/20
SHA-256 :CE362AF57A83FC73C51C6D71B92541AD1B9CF2530361F74E37C2296457CAB816
- Enhanced system stability.
- Enhanced input validation and refactored legacy string handling routines to ensure robust memory management.
- Mitigated security risks in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
- Implemented comprehensive validation and expanded command filtering in the web history API.
- Strengthened input validation and directory handling in the VPN configuration upload interface.
- Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
Download
Download
I had to use the download link provided here, it wasn't found within the router's update check function.
Edit: Seems like everything came up normally after the flash.
