Asus RT-AX86U error log: BWDPI: [BWHIS] Revert process and free memory
manocinca
Hi..
I have a problem with an Asus RT-AX86U router.
firmware normal asus original: ver: 3.0.0.4.388_22068
The log is full of the following error, which makes an entry every minute.
Jan 16 23:14:34 BWDPI: [BWHIS] Revert process and free memory (pid=18820)
Jan 16 23:14:39 BWDPI: [BWHIS] Revert process and free memory (pid=19202)
Jan 16 23:16:45 BWDPI: [BWHIS] Revert process and free memory (pid=19214)
Jan 16 23:16:50 BWDPI: [BWHIS] Revert process and free memory (pid=19502)
Jan 16 23:18:56 BWDPI: [BWHIS] Revert process and free memory (pid=19521)
Jan 16 23:19:01 BWDPI: [BWHIS] Revert process and free memory (pid=19822)
Jan 16 23:21:06 BWDPI: [BWHIS] Revert process and free memory (pid=19831)
Jan 16 23:21:11 BWDPI: [BWHIS] Revert process and free memory (pid=20117)
Jan 16 23:23:17 BWDPI: [BWHIS] Revert process and free memory (pid=20129)
Jan 16 23:23:22 BWDPI: [BWHIS] Revert process and free memory (pid=20437)
Jan 16 23:25:28 BWDPI: [BWHIS] Revert process and free memory (pid=20451)
Jan 16 23:25:33 BWDPI: [BWHIS] Revert process and free memory (pid=20752)
Jan 16 23:27:39 BWDPI: [BWHIS] Revert process and free memory (pid=20765)
Jan 16 23:27:44 BWDPI: [BWHIS] Revert process and free memory (pid=21348)
Jan 16 23:29:50 BWDPI: [BWHIS] Revert process and free memory (pid=21357)
Jan 16 23:29:55 BWDPI: [BWHIS] Revert process and free memory (pid=21629)
Jan 16 23:32:00 BWDPI: [BWHIS] Revert process and free memory (pid=21643)
Jan 16 23:32:05 BWDPI: [BWHIS] Revert process and free memory (pid=21913)
Jan 16 23:34:11 BWDPI: [BWHIS] Revert process and free memory (pid=21925)
Jan 16 23:34:16 BWDPI: [BWHIS] Revert process and free memory (pid=22202)
Jan 16 23:36:22 BWDPI: [BWHIS] Revert process and free memory (pid=22214)
Jan 16 23:36:27 BWDPI: [BWHIS] Revert process and free memory (pid=22676)
What can I do about it? And what is it anyway?
The router works normally, but the GUI has slowed down and sometimes you can't even reach it. And the router freezes about every 2 weeks. Since these errors were published in LOG.
J23
Seeing many many reports of memory issues on any of the new Asus and Merlin firmware. There is a problem and it needs to be fixed only time will tell.
bbunge
Part of the Furniture
Do you have a USB drive connected to the router? If so switch to USB2 operation in the Administration/System area (as a test) and if a hard drive make sure it is externally powered. Power cycle the router by pulling the power cord from the mains and leave it unplugged for 30 to 60 seconds. Power back up and check the memory usage from time to time. My router trimmed the used RAM in the past day from 61% to 57%. I have seen the RAM usage go up to 97% but the router does keep working.
Yes, others have reported high memory usage but the router should keep working. Some blame a memory leak but I have not experienced that.
zthomasp
I wanted to share I just purchased a RT-AX86S today (vanilla, no customizations other than signing into PPPoe and doing a few DHCP reservations) and it prompted a firmware update that created a ton of issues even pulling up the GUI for the router.
I downgraded to the firmware immediately prior to the latest one, and turned OFF automatic updates. Things are much more stable and I have a hunch this was related to the router not having enough memory to load the page, or being distracted with some other process creating errors. The firmware that is indeed working for me is Firmware Version:3.0.0.4.388_21709 in case this helps someone else.
Other than this issue the router seems to be working.
razor_bird
Remember, the RT-AX86S is a completely different Router, despite the marketing. It has half the memory, even though it's newer.
My 68U is having frequent hang-ups ever since I've installed the new firmware. It just loses all connections, then takes forever to restart.
manocinca
I don't have any usb device connected to the router.
Now i unpluged all device and all wifi device. Just my notebook connected to the router. I disabled qos in firewall and disabled aiprotection and disabled all memory demanding service feature. But no resolved the problem.
OzarkEdge
Be sure to reset the firmware to its defaults before you configure it from scratch. I suggest you configure it minimally to begin with and test before adding on. My install notes suggest a minimal configuration.
OE
ColinTaylor
Go to Administration - Privacy and Withdraw from any agreements there.
