asus RT-AX86u random reboots, wan light red
jbee90
my router has been randomly rebooting and then all lights come back with the wan led going off, a couple of seconds later it turns red, this just happened five times within an hour. i am running merlin 386.7_2 how can i tell if i am being hacked?
You may want to check the power supply/input voltage. The router will reboot if the voltage drops.
i never had this problem before and my set up is the same with my router plugged into a apc power bar, i did add a device to my wifi, is it possible that the laptop can force my router to shut down? i do have flex qos and ai protection enabled
