I have had my RT-AX86U with Merlin (latest firmware 3004.388.9_2) running for a few years. Recently, it has occasionally stopped working completely, and this issue recurred today. I noticed the problem around 1:10 pm. No DHCP, no internet, no ssh, and it was back to its normal working state after power cycled. I took a look at the syslog and noticed the issue started at 12:54:06 am this early morning. The timestamp was changed to December 31 suddenly. The timestamp was recovered at 12:54:55, but the syslog stopped at 12:55:22. Any help is greatly appreciated.
Sep 13 12:54:05 rc_service: watchdog 1650:notify_rc start_dnsmasq
Sep 13 12:54:05 custom_script: Running /jffs/scripts/service-event (args: start dnsmasq)
Sep 13 12:54:05 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf)
Sep 13 12:54:06 Diversion: restarted Dnsmasq to apply settings
Sep 13 12:54:06 stubby[18216]: Read config from file /etc/stubby/stubby.yml
Sep 13 12:54:06 stubby[18216]: Stubby version: Stubby 0.4.2
Sep 13 12:54:06 dnsmasq[18218]: cannot open log /opt/var/log/dnsmasq.log: Read-only file system
Sep 13 12:54:06 dnsmasq[18218]: FAILED to start up
Dec 31 19:00:25 syslogd started: BusyBox v1.25.1
Dec 31 19:00:25 kernel: klogd started: BusyBox v1.25.1 (2025-04-28 17:28:04 EDT)
Dec 31 19:00:25 kernel: Booting Linux on physical CPU 0x0
Dec 31 19:00:25 kernel: Linux version 4.1.52 (merlin@ubuntu-dev) (gcc version 5.5.0 (Buildroot 2017.11.1) ) #2 SMP PREEMPT Mon Apr 28 17:48:56 EDT 2025
Dec 31 19:00:25 kernel: CPU: AArch64 Processor [420f1000] revision 0
Dec 31 19:00:25 kernel: Detected VIPT I-cache on CPU0
Dec 31 19:00:25 kernel: alternatives: enabling workaround for ARM erratum 845719
Dec 31 19:00:25 kernel: On node 0 totalpages: 248064
Dec 31 19:00:25 kernel: DMA zone: 3584 pages used for memmap
Dec 31 19:00:25 kernel: DMA zone: 0 pages reserved
Dec 31 19:00:25 kernel: DMA zone: 248064 pages, LIFO batch:31
Dec 31 19:00:25 kernel: PERCPU: Embedded 15 pages/cpu @ffffffc03ffb3000 s21400 r8192 d31848 u61440
Dec 31 19:00:25 kernel: pcpu-alloc: s21400 r8192 d31848 u61440 alloc=15*4096
Dec 31 19:00:25 kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Dec 31 19:00:25 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 244480
Dec 31 19:00:25 kernel: Kernel command line: root=ubi:rootfs_ubifs ubi.mtd=0 rootfstype=ubifs coherent_pool=4M cpuidle_sysfs_switch pci=pcie_bus_safe rootwait
Dec 31 19:00:25 kernel: PID hash table entries: 4096 (order: 3, 32768 bytes)
Dec 31 19:00:25 kernel: Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
Dec 31 19:00:25 kernel: Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
Dec 31 19:00:25 kernel: Memory: 933732K/992256K available (5034K kernel code, 1855K rwdata, 1692K rodata, 232K init, 553K bss, 58524K reserved, 0K cma-reserved)
Dec 31 19:00:36 wlceventd: wlceventd_proc_event(685): eth6: Auth XX:XX:XX:XX:XX:XX, status: Successful (0), rssi:0
Dec 31 19:00:36 custom_script: Running /jffs/scripts/service-event (args: start ntpd)
Dec 31 19:00:36 ntpd: Started ntpd
Dec 31 19:00:36 hostapd: eth6: STA XX:XX:XX:XX:XX:XX IEEE 802.11: associated
Dec 31 19:00:36 kernel: sda: sda1
Dec 31 19:00:36 wlceventd: wlceventd_proc_event(722): eth6: Assoc XX:XX:XX:XX:XX:XX, status: Successful (0), rssi:-27
Dec 31 19:00:36 kernel: sd 0:0:0:0: [sda] Attached SCSI removable disk
Dec 31 19:00:36 hostapd: eth6: STA XX:XX:XX:XX:XX:XX RADIUS: starting accounting session 5CAFA965FFBFD0DA
Dec 31 19:00:36 hostapd: eth6: STA XX:XX:XX:XX:XX:XX WPA: pairwise key handshake completed (RSN)
Sep 13 12:54:55 ntpd: Initial clock set
Sep 13 12:54:55 rc_service: ntpd_synced 2276:notify_rc restart_stubby
Sep 13 12:54:55 rc_service: ntpd_synced 2276:notify_rc restart_diskmon
Sep 13 12:54:55 rc_service: waitting "restart_stubby" via ntpd_synced ...
Sep 13 12:54:55 custom_script: Running /jffs/scripts/service-event (args: restart stubby)
Sep 13 12:55:19 networkmap: Error locking /var/lock//usr/networkmap/nmp_conv_type.js.lock: 2 No such file or directory
Sep 13 12:55:19 networkmap: Error unlocking -1: 9 Bad file descriptor
Sep 13 12:55:19 networkmap: Error locking /var/lock//usr/networkmap/nmp_vendor_type.js.lock: 2 No such file or directory
Sep 13 12:55:19 networkmap: Error locking /var/lock//usr/networkmap/nmp_bwdpi_type.js.lock: 2 No such file or directory
Sep 13 12:55:22 YazFi: YazFi v4.4.4 completed successfully
Sep 13 13:10:22 rc_service: service 2648:notify_rc stop_vpnclient1
Sep 13 13:10:22 custom_script: Running /jffs/scripts/service-event (args: stop vpnclient1)
Sep 13 13:10:22 ovpn-client1[2818]: event_wait : Interrupted system call (fd=-1,code=4)
Sep 13 13:10:22 ovpn-client1[2818]: ovpn-route-pre-down tun11 1500 0 10.16.0.15 255.255.0.0 init
Sep 13 13:10:22 custom_script: Running openvpn-event
Sep 13 13:10:22 ovpn-client1[2818]: Closing TUN/TAP interface
