dave14305
Part of the Furniture
SHA-256 :6CE30822668E16C8D08CB96019DD8F1FC30360E0EA1F740664CB50235514211D
- Enhanced system stability.
- Enhanced input validation and refactored legacy string handling routines to ensure robust memory management.
- Mitigated security risks in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
- Implemented comprehensive validation and expanded command filtering in the web history API.
- Strengthened input validation and directory handling in the VPN configuration upload interface.
- Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
www.asus.com
RT-AX88U Pro|WiFi Routers|ASUS USA
AX6000 Dual Band WiFi 6 Router, Dual 2.5G Port, 2.0 GHz Quad-core CPU, AiProtection Pro, WPA3, Parental Control, Mesh WiFi support, Adaptive QoS, Port Forwarding, WAN aggregation, free network security and AiMesh support
www.asus.com
