Release ASUS RT-BE88U Firmware version 3.0.0.6_102_39112 2025/10/29
Ameenhuus
Firmware version 3.0.0.6_102_39112-g7a02961_1472-g67069
- Release Note -
System Improvements:
1.Enhanced system stability.
2.Enhanced input validation and refactored legacy string handling routines to ensure robust memory management.
3.Mitigated security risks in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
4.Implemented comprehensive validation and expanded command filtering in the web history API.
5.Fixed a privilege escalation vector in the IFTTT token exchange mechanism
6.Strengthened input validation and directory handling in the VPN configuration upload interface.
7.Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
8.Guest Network Pro has been enhanced with IPv6 support.
Just checking for update on the router settings shows the update?
Sorry, I copied and edited the text and forgot to remove the Pro. (I've edited it now.) I don't see it on the Asus site yet, but I do when I check the router for new firmware.
