Asus RT-N65R DualBand Wireless N750 Gigabit Router
RTN
Dual Processor Design Maximizes Dual-Band Throughput
Dual processors feature one dedicated to 2.4GHz and another to 5GHz, offering the best concurrent
throughput with dual-band 2.4GHz and 5GHz operation at up to a combined 750Mbps.
  • 2.4GHz and 5GHz concurrent dual-band transmissions with dual processor design for stronger
    signals and faster connection rates up to 750Mbps combined
  • Gigabit Ethernet ports with hardware NAT for the fastest, most reliable internet performance
  • Twin USB 3.0 ports provide SuperSpeed file, printer, and 3G sharing
  • Download Master for wireless data storage and access to router-connected USB storage devices
  • ASUSWRT dashboard UI offers easy setup, signal monitoring, and network application control
Specifications
  • Product Segment N750/N600 advanced performance; 300+450Mbps
  • Data Rate
    802.11a : 6,9,12,18,24,36,48,54Mbps
    802.11b : 1, 2, 5.5, 11Mbps
    802.11g : 6,9,12,18,24,36,48,54Mbps
    802.11n : up to 450Mbps
  • Antenna Internal antenna x 3
  • Operating Frequency 2.4G~2.4835GHz /5.1~5.8GHz
  • Network Standard IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IPv4, IPv6
http://usa.asus.com/Networks/Wireless_Routers/RTN65R/ :rolleyes:
I knew I should have waited!
In my mind the V2 USB said interim model. But I really wanted to see if it helped my VOIP problems. And I have only been running the 66 for about a month when I determined that Merlin's build satisfied all my minimum needs. Arrgh.
I'd still want to see disk benchmarks first. I doubt the CPU has the muscle or the bandwidth to push a full 5 Gbits over USB3.
I see even more routers coming from Asus in the near future, based on things I have noticed in the latest GPL code...
Asus RT-N67U & RT-N36U3 ;)
# Ralink platform, linux-3.x
export RT-N67U := IPV6SUPP=y MIPS32=r2 RALINK=y RT3883=y BBEXTRAS=y USBEXTRAS=y EBTABLES=y SAMBA3=y MODEM=y MODEMPIN=y PARENTAL2=y ACCEL_PPTPD=y PRINTER=y USB="USB" APP="network" AUTODICT=y LANWAN_LED=y BUILD_NAME="RT-N67U" RTN56U=y \ XHCI=y \ NTFS3G=y \ BOOT_FLASH_TYPE=SPI \ GMAC2=y \ SWITCH_CHIP=CHIP_RTL8368MB SWITCH_CTRLIF=CTRLIF_MDIO
export RT-N65U := IPV6SUPP=y MIPS32=r2 RALINK=y RT3883=y NTFS=y BBEXTRAS=y USBEXTRAS=y EBTABLES=y SAMBA3=y MODEM=y MODEMPIN=y HTTPS=y WEBDAV=y CLOUDSYNC=y PARENTAL2=y ACCEL_PPTPD=y PRINTER=y USB="USB" APP="network" AUTODICT=y LANWAN_LED=y SHP=y BUILD_NAME="RT-N65U" RTN56U=y ODMPID=y \ XHCI=y \ BOOT_FLASH_TYPE=SPI \ INIC_CHIP=RT3352_MII \ HTTPS=y \ SWITCH_VLAN=y SWITCH_CHIP=CHIP_RTL8367RB SWITCH_CTRLIF=CTRLIF_MDIO WLAN2_ON_SWITCH_GMAC2=y SWITCH_LAN_WAN_SWAP=y
export RT-N36U3 := IPV6SUPP=y MIPS32=r2 RALINK=y RT3883=y NTFS3G=y BBEXTRAS=y USBEXTRAS=y EBTABLES=y SAMBA3=y MODEM=y MODEMPIN=y PARENTAL2=y ACCEL_PPTPD=y PRINTER=y USB="USB" APP="network" AUTODICT=y LANWAN_LED=y SHP=y BUILD_NAME="RT-N36U3" RTN56U=y \ XHCI=y \ BOOT_FLASH_TYPE=NOR \ GMAC2=y \ SWITCH_CHIP=CHIP_RTL8367RB SWITCH_CTRLIF=CTRLIF_MDIO
GPL Source: GPL_RT_N66U_B1_3004220 :rolleyes: http://www.hub.ru/wiki/Devices_ASUS_WL_Routers#RTN
Memory, storage and CPU specs
Picked one of these up this morning at Best Buy ($129) as my Belkin F7D3302 v1 was DOA when I woke up.
Here's some quick info after poking around in telnet:
free
total used free shared buffers
Mem: 126032 31528 94504 0 4352
Swap: 0 0 0
Total: 126032 31528 94504
df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 6.9M 6.9M 0 100% /
tmpfs 61.5M 436.0K 61.1M 1% /tmp
devfs 61.5M 0 61.5M 0% /dev
cat /proc/cpuinfo
system type : Ralink SoC
processor : 0
cpu model : MIPS 74Kc V4.12
BogoMIPS : 249.34
wait instruction : yes
microsecond timers : yes
tlb_entries : 32
extra interrupt vector : yes
hardware watchpoint : yes, count: 4, address/irw mask: [0x0000, 0x0100, 0x0580, 0x0090]
ASEs implemented : mips16 dsp
shadow register sets : 1
kscratch registers : 0
core : 0
VCED exceptions : not available
VCEI exceptions : not available
In summary:
Flash: 64M
RAM: 128M
CPU: ~500mhz? Ralink
