I have requested (a year ago) from ASUS to add a feature to the RT-N66 router to provide copy and paste for the MAC filter list and IP addresses. As of the last FW update, they have not implemented this significant time saver. I wonder why?![]()
Some browsers have issues dealing with the Javascript-based key filtering. Try Shift-Insert if Ctrl-V does not work.
@RMerlin - Thanks for the tip... Shift-Insert works. I wonder why ASUS has to be different instead of using the standard Ctrl-V![]()
If Ctrl-V does not work, try a right mouse-click on the data field and select Paste.Shift-Ins isn't something Asus support, it's something your browser support. The problem is Asus filtering invalid keys. Some browsers will refuse Ctrl-V as it treats it like a user-entered key sequence, other browsers will accept it as it considers it to be a system key sequence of some sort.
Just your usual situation where not all browsers handle things the same way.
Thread starter | Title | Forum | Replies | Date |
B | Issue with wired clients on ASUS N56U | ASUS N Routers & Adapters | 0 | |
J | I can't reset or access ASUS TUF-AX6000 GUI | ASUS N Routers & Adapters | 8 |
Welcome To SNBForums
