ASUS RT-N66R Fails to upload Firmware 380.59
Mike D
I have an ASUS RT-N66R running 378.56_2 and tried to upgrade it to the latest RT-AC66U_380.59_0.trx. When I do so it fails with the following error message. My RT-N66U upgrades fine with the same image. I was under the impression that the images supported both boxes. Did something change in recent releases. I tried 380.58 too with the same outcome
"Firmware upgrade unsuccessful. This may result from incorrect image or error transmission. Please check the version of firmware and try again."
Remove your connected USB devices before update the FW.
I was able to load the latest ASUS factory firmware
3264? And now, you will not be able to try any others (without jumping through hoops).
