Asus RT-N66u retest correlation with previous results
jaydee
It seems that the new test setup doesn't correlate too well to the previous test setup.
If I understand the test correctly, this is the change for the 4 current tests
Diff Test (3 Stream )
52% Downlink 2.4GHz, 20 MHz
54% Uplink 2.4GHz, 20 MHz
128% Downlink 5 GHz, 40 MHz
31% Uplink 5 GHz, 40 MHz
I am guessing that the client change is a big driver of these diffs, and if that is the case, it will be difficult to compare previous test results.
Both the client and test method make comparison difficult. That is why I am retesting some of the more popular routers with the new method.
