Release ASUS TUF-AX6000 Firmware version 3.0.0.4.388_33965 (2025/10/23)
I'm on firmware 3.0.0.4.388_31374-g617d05c
This firmware is not available for download anymore though. In ASUS world this means there is newer minimum required firmware version for this model router. Going back is not recommended.
I have switched off the firmware updates to be sure that it won't update by himself.
It may still auto upgrade (very likely) according to ASUS documents. It was made official some time ago ASUS reserves the right to auto upgrade firmware when minimum required firmware version changes.
Hi and thank you for your feedback.
The latest stable version that has been recommended over here (but without extensive testing) is TUF-AX6000_3.0.0.4_388_33427-gc525e4e.
Any specific reason why you chose 3.0.0.4.388_31374-g617d05c and/or how did you choose that specific version?
Glad you found a stable setup. Any clue regarding possible security risks?
Thanks!
I have choose one of the earliest firmware.
I know that it might be a bit risky.
But I'm not enabling
It may still auto upgrade according to ASUS documents. It was made official some time ago ASUS reserves the right to auto upgrade firmware when minimum required firmware version changes.
It was not pushed a force upgrade.
In 71 days it is long enough....
Considering the firmware is from 2023.
Maybe because I didn't agree to their terms and conditions inside firmware.
It's in there a paragraph that states if I am not accepting the t&c I'm not able to receive latest updates.
Could be that or could be they know that they have an problematic firmware.
Anyway I'm happy that I can use the hardware for the purpose I bought it.
Ah,regarding security....
Got a 30 number/letter passwords everywhere on it.
But if someone want and have the knowledge it might get in.
Nothing is unbreakable these days.
Life is tough with this TUF. For some reason ASUS have issues with MediaTek devices. They had some budget ones in AC-class and they were short lived reaching EoL faster than others. :confused:
