Asuswrt-Merlin 3.0.0.4.270.25 is out
Edit: Fixed my own problem. Had to format my USB stick in ext3 format. Took forever to find a Windows utility that supports ext3.
Can you post the steps to format your USB drive in ext3?
Can it be done using Telnet?
Thanks!
I noticed a bug with IPv6 on my N66U. When it does a soft-reset, where it doesn't completely reboot, it will forget the IPv6 prefix and address. For example, when changing port mapping or adding/removing devices from the manually assigned IP list. For IPv6 I'm using Native with DHCP-PD. If I then manually reboot, it will acquire an IPv6 address as expected.
I have not tested this with the latest beta, because of the wireless issues.
