Release Asuswrt-Merlin 3006.102.7 is now available
ASUS just released new firmware today "ASUS RT-BE58 GO Firmware Version 3.0.0.6.102_39125",, so I downloaded their new firmware, extracted their files from the zip, hashed the files, and tried to firmware upgrade the new file, same error as Merlin firmware "It started to "Applying Settings" and then kicked me back to the Main Login page."
So I ran the the firmware check update in the software, which found the new firmware from ASUS, so I ran the install and it worked, and updated the RT-BE58 Go to V3.0.0.6.102_39125.
I then went to install Merlin's ASUS firmware "RT-BE58_GO_3006_102.7_2_nand_squashfs.pkgtb" file and "It started to "Applying Settings" and then kicked me back to the Main Login page."
Any thoughts of what else I can try @RMerlin ? (If this needs to be moved to a seperate thread please do so).
I have previously answered your query about this router and updating its firmware. I suggest you open a new thread because it has NOTHING to do with the firmware release or with Merlinware.
Just to test for you I have applied the latest stock firmware to mine ... see pic below ...
It does indeed state "Applying Settings for quite a while - but eventually displays a percentage updating until done.
I can only assume that something is wrong with your method of updating. Try using an ethernet cable directly between the device you are updating from and this router.
EDIT: I will now revert to Merlinware 3006.102.7.2 again - and post the result back to this post. Here she blows ...
and back to Merlinware [with apologies for screen space taken up on an off topic series of posts !]
I don't believe this is specifically related to this build, however I have noticed that at some points networkmap will stop refreshing client changed and either requires a restart of the main router or a "killall -9" of the networkmap service to start functioning. This can be seen in two ways; first the clients stop refreshing (the obvious way) when a client connects or disconnects, which is true across the main network client list, AiMesh, and Network pages. Second is noticing that the CPU usage drops to nearly nothing across all cores as when networkmap is functioning it averages about ~20-25% across the cores. Restarting the service kicks things back in gear and clients immediately start refreshing thereafter.
All my connection for firmware updates for all my routers are ethernet only. Since your RT-BE58 Go is an AiMesh Node and NOT setup as the main AiMesh router, I thought maybe that might have something to do with the firmware update failing for me, but I found out that is incorrect.
I tested the firmware update with two separate computers (Windows 10 Laptop & Windows 11 PC). The Laptop tested using Chrome & Microsoft Edge browser to get to the GUI (failed firmware update both times). The PC test with Chrome browser (failed firmware update)
I then went to my VMWare Virtual Workstation I run on my laptop with a Virtual Windows 10 Image running, made a copy of the firmware file and put it on the virtual drive C: in a folder called \TEMP and reran the firmware upgrade via the virtual Chrome Browser and it worked this time.
Thanks for your info, and now the setup and documentation of my RT-BE58 GO can begin!
