Release Asuswrt-Merlin 3006.102.7 is now available
There's a few people here, myself included, who've used managed switches to put wired devices in a GNP VLAN because of AiMesh nodes that don't support wired VLAN tagging (only my main router can do that ). I can't speak for those other people but I have not experienced any client dropouts (wired or wireless) like what's being described, so I think that's solid evidence of it being something about the Asus hardware doing the wired tagging and not a result of having wired clients in the VLANs.
It's worth noting that I have wired VLAN on the main router with no issues, this is specifically on a node that supports it, but with GNP VLAN clients losing connectivity on the specific node when in use.
Try the usual troubleshooting steps:
  • Clear browser cache
  • Shutdown the router and physically remove power from the router, if router has a physical ON/OFF switch or button then with the power disconnected from the router turn that switch/button on for at least 30 second then turn it back off, wait a few minutes, then reconnect power to the router and power the router on
  • When manually flashing firmware make sure to have the computer connected directly to the router by Ethernet cable, do not use WiFi, do not go through any extenders or switches or similar
  • Prior to flashing the firmware disconnect any router attached USB device, only reattach the USB device after the firmware has been successfully flashed
  • Try a different web browser
  • Try a different computer
  • Temporarily disable any security software on the computer prior to manually flashing the router firmware
  • Temporarily disable any browser extensions or addons prior to manually flashing the router firmware
  • Avoid, if possible, manually flashing the firmware from a remote location using VPN or other remote access method(s)
Hello, good day!
Has anyone been able to successfully upgrade GT-AX6000 from 102.6 to 102.7? I'm having a very hard time trying to do it. I have tried all the items suggested by @bennor but I always get "Firmware upgrade unsuccessful". I have also tried:
- Factory reset the router and try to upgrade
- Put router in rescue mode and upload the firmware from there
But no success. Any other ideas? Thanks in advance!
Interesting. Now I'm glad my nodes don't support wired VLAN and I had to get managed switches to do it.
Not experiencing this issue with GT-AX6000 or GT-AXE16000 nodes, both with Merlin 3006.102.7 firmware.
