102.7 Alpha Builds available
Tried to install and run the ControlD Command Line Daemon (https://docs.controld.com/docs/ctrld). The script appears to install properly. When I try and start the ctrld service, I get a "ctrld: not found" error. I reverted to 102.6 firmware and everything works as expected.
This happens to me after first installing ctrld because the shell script directory just got added to a startup script that modifies the PATH environment variable. However, PATH itself is not actually modified upon completed installation.
Upon router reboot the issue is solved because PATH is now correctly including the /jffs/controld directory from that point forward.
