Asuswrt RT-AC/X Routers Support Time Machine & IPSec?
HND platform is on 4.1.x kernel.
By the way, with no TrendMicro enabled AC86U has ~240MB RAM available, AX88U ~580MB. I don't know if it's good enough for you. I expect AX68U to be similar to AC86U (512MB RAM) and AX86U to be similar to AX88U (1GB RAM). All models use ARMv8 CPU cores with AES.
It appears that the xt_socket and xt_TPROXY modules are still included in the Linux 4.1.x kernel source.
I suppose the next logical question is whether they're compiled and available under the Asuswrt-Merlin 4.1.x kernel?
Will you run the following modprobe commands on one of your HND routers to see if they install?
# modprobe xt_socket
# modprobe xt_TPROXY
# lsmod | grep xt_
Much Appreciated!
Gary
What I do with the commands, SSH?
xt_TPROXY 5057 0
xt_socket 3926 0
I don't speak Greek. :)
xt_TPROXY 5057 0
xt_socket 3926 0
Pretty good for not speaking Greek, but apparently fluent in Sarcasm. ;)
It looks like I'm good to continue my search for an HND router.
Thank you for confirming!
