AX56U - Error adding iptables rule when using IPv6
brianto
HI,
AX56U with merlin 384.18
I have iptables rules in firewall-start like this:
iptables -t nat -A PREROUTING -i br0 -p udp --dport 53 -j DNAT --to 23.21.43.50:1512
iptables -t nat -A PREROUTING -i br0 -p tcp --dport 53 -j DNAT --to 23.21.43.50:1512
It works when using IPv4 only.
When I activated IPv6, using tunnelbroker setting, I got these error messages:
[ERROR cmdlist] cmdlist_ucast_create_bin,1904: Could not ipv4_addresses_table_add
IPv6 works, but those rules wasn't loaded. Tried to disable IPv6 firewall but the errors persist.
Any helps, tips, pointers for this problem?
Many thanks in advance.
HI,
The problem with ipv6 is that there is limits to the firewall rules with asuswrt in general. even merlin asuswrt. it is the same issue. the trick is that you either have to not use IPV6 or block it for what ever you don't want it to be able to do and allow it for only whatever you want it to do.
Thanks for the tips.
Somehow, changing the destination ip address to another provider is what works for me.
Now, I can bypass transparent dns proxy and still have IPv6.
Cheers.
I spoke too soon
While the errors disappear when I look into dmesg, the result is still the same.
When IPV6 works, the IPV4 iptables rules are abandoned.
When I disable IPV6, the iptables rules are working.
Cheers.
