AX57 go as wireless AIMESH
Jherb
I have an AX86u PRO as a main router. I set up the ax57go as an AIMESH with an ethernet cable, and it connected fine.
When I disconnect the ethernet cable, the aimesh node goes down and remains disconnected. Even when very close to the main router.
The app and web gui show it as not online. I've rebooted, started the install from scratch, etc but nothing helps.
Can the AX57go act as a wireless mesh? Is there something I need to do to make it work wirelessly as a node?
On the main router you may need to check the Backhaul Priority setting for the AiMesh Node and adjust if necessary.
Or one may have to delete the AiMesh Node and readd it (using WiFi rather than Ethernet backhaul).
I forgot to mention that when I try to add it wirelessly, it fails at about 85%. I tried this many times and it fails every time. This is why I resorted to ethernet for the setup.
