AX58U upgrade?
mrboonmee
What is the logical upgrade if more range is needed from AX58U? I see some newer models like AX5400 and AX88U PRO etc
If that RT-AX88U Pro is within your budget, that is the best bang-for-the-buck hardware you can buy today.
you can go with GT-AX6000
@mrboonmee already has one GT-AX6000. Perhaps they are looking for something cheaper as AiMesh node?
I've had the AX68U for months and its been terrific though I have no idea about your budget and type of range you seek. Rock solid router though :)
Better define your expectations and working conditions.
RT-AX88U Pro will have a very similar range to GT-AX6000.
TUF-AX5400 will likely have similar range to RT-AX58U, at least for 2.4 GHz.
Range depends on many factors house construction , how crowded your neighborhood is re wifi . In the country house my signal is good for 800 feet outside the house AX1100pro , in the city might be good for 200 feet outside the house AXE1100
PS, the 2/26/24 firmware release, v 3.0.0.4.388_24646 made dramatic improvements in performance..range is nearly double what it was the previous version and the auto update worked perfectly. Rock on Asus!
Must be RT-AX68U? AX58U yet to receive firmware this year. thanks for that
