AX86 wan got disconnected everytime aimesh node is added or when some setting according to netwerk/wifi/lan is changed
Krism
Running beta2 on my ax86 (but problem already existed in the alpha and beta1 version). As soon as I change some setting concerning wlan/lan/ ... my wan connection goes down. Cannot restore it, only reboot works.
Problem also exists when the aimesh node is added to the ax86. As soon the slave node is registered, wan connection goes down.
Connected via cable I can still discover local network devices but with wifi connection I cannot but only using ipadresses. So it looks like dns is also in trouble.
I managed to get some logging, please help:
Dec 26 21:30:13 rtaxbeast kernel: br0: port 9(wl0.3) entered disabled state
Dec 26 21:30:13 rtaxbeast kernel: _blog_emit, blogp = 0x2300
Dec 26 21:30:14 rtaxbeast kernel: _blog_emit, blogp = 0x2260
Dec 26 21:30:14 rtaxbeast kernel: _blog_emit, blogp = 0x2320
Dec 26 21:30:14 rtaxbeast kernel: _blog_emit, blogp = 0x12cc
Dec 26 21:30:14 rtaxbeast kernel: _blog_emit, blogp = 0x130c
Dec 26 21:30:14 rtaxbeast kernel: _blog_emit, blogp = 0x2300
Dec 26 21:30:14 rtaxbeast kernel: _blog_emit, blogp = 0x12ac
Dec 26 21:30:15 rtaxbeast kernel: _blog_emit, blogp = 0x22c0
Dec 26 21:30:15 rtaxbeast kernel: CFGP2P-ERROR) wl_cfgp2p_find_ndev : p2p inactive
Dec 26 21:30:15 rtaxbeast kernel: wl0: random key value: 816EC75EFA79FC880321039530A8989DFA0B91E9E78E08908D9A4637C96E7B8C
Dec 26 21:30:15 rtaxbeast kernel: wl0: set timeout 5 secs to wait dev reg finish
Dec 26 21:30:15 rtaxbeast kernel: wfd_unregisterdevice Successfully unregistered ifidx 2 wfd_idx 0
Dec 26 21:30:15 rtaxbeast kernel: br0: port 8(wl0.2) entered disabled state
Dec 26 21:30:15 rtaxbeast kernel: device wl0.2 left promiscuous mode
Dec 26 21:30:15 rtaxbeast kernel: wl0: random key value: 8C8968F6C87D998B41B602D49C5FC9B7E2079094C981054FB87EAB4ABF7CDD7F
Dec 26 21:30:15 rtaxbeast kernel: CFG80211-ERROR) wl_cfg80211_event : ignore event 12, not interested
Dec 26 21:30:16 rtaxbeast kernel: CFG80211-ERROR) wl_notify_connect_status : Invalid ndev status 4
Dec 26 21:30:16 rtaxbeast kernel: wfd_unregisterdevice Successfully unregistered ifidx 3 wfd_idx 1
Dec 26 21:30:16 rtaxbeast kernel: CONSOLE: 023335.661 wl1.0: wlc_ampdu_flush_scb_tid flushing 0 packets for 34:97:f6:6e:c8:98 AID 16 tid 0
Dec 26 21:30:16 rtaxbeast kernel: CONSOLE: 023335.661 wl1.0: wlc_ampdu_flush_scb_tid flushing 0 packets for 34:97:f6:6e:c8:98 AID 16 tid 5
Dec 26 21:30:16 rtaxbeast kernel: CONSOLE: 023335.661 wl1.0: wlc_ampdu_flush_scb_tid flushing 0 packets for 34:97:f6:6e:c8:98 AID 16 tid 6
Dec 26 21:30:16 rtaxbeast kernel: CONSOLE: 023335.661 wl1: random key value: 726A303C8252FDFA3CF900619A514014407EF08E392C035440862FD897D9152E
Dec 26 21:30:16 rtaxbeast kernel: CONSOLE: 023335.662 dngl_finddev: slave 3 not found
Dec 26 21:30:16 rtaxbeast kernel: CONSOLE: 023335.663 dngl_finddev: slave 3 not found
Dec 26 21:30:16 rtaxbeast kernel: CFGP2P-ERROR) wl_cfgp2p_find_ndev : p2p inactive
Dec 26 21:30:16 rtaxbeast kernel: wl0: set timeout 5 secs to wait dev reg finish
Dec 26 21:30:16 rtaxbeast kernel: wfd_unregisterdevice Successfully unregistered ifidx 1 wfd_idx 0
Dec 26 21:30:16 rtaxbeast kernel: br1: port 1(wl0.1) entered disabled state
Dec 26 21:30:16 rtaxbeast kernel: device wl0.1 left promiscuous mode
Dec 26 21:30:18 rtaxbeast kernel: _blog_emit, blogp = 0x2260
Dec 26 21:30:18 rtaxbeast kernel: CFGP2P-ERROR) wl_cfgp2p_find_ndev : p2p inactive
Dec 26 21:30:18 rtaxbeast kernel: CFG80211-ERROR) wl_event_handler : No wdev corresponding to bssidx: 0x3 found! Ignoring event.
Dec 26 21:30:18 rtaxbeast kernel: wfd_unregisterdevice Successfully unregistered ifidx 2 wfd_idx 1
Dec 26 21:30:18 rtaxbeast kernel: CFG80211-ERROR) wl_add_remove_eventmsg : Get event_msgs error (-19)
Dec 26 21:30:18 rtaxbeast kernel: br0: port 10(wl1.2) entered disabled state
Dec 26 21:30:18 rtaxbeast kernel: device wl1.2 left promiscuous mode
Dec 26 21:30:18 rtaxbeast kernel: CONSOLE: 023338.043 wl1: random key value: C173E4C9C4C118970C4200A7E40C19BAF0D50EBB9E4004D9FC9AB24F32F0D1A4
Dec 26 21:30:18 rtaxbeast kernel: CONSOLE: 023338.043 wl1: wlc_txbf_delete_link_serve failed for aa:c6:6a:38:51:3e
Dec 26 21:30:18 rtaxbeast kernel: CONSOLE: 023338.044 wl1: random key value: A2F8A9CA9D82872B44BB00F6240D2FB74BCADB30D7DB012E1BC0513C3DD7A964
Dec 26 21:30:18 rtaxbeast kernel: CONSOLE: 023338.044 dngl_finddev: slave 2 not found
Dec 26 21:30:18 rtaxbeast kernel: CONSOLE: 023338.086 dngl_finddev: slave 1 not found
Dec 26 21:30:18 rtaxbeast kernel: CONSOLE: 023338.086 dngl_finddev: slave 2 not found
Dec 26 21:30:18 rtaxbeast kernel: CONSOLE: 023338.117 wl1: wlc_dotxstatus: bail: tx status for invalid linkmem scb:00000000
Dec 26 21:30:18 rtaxbeast kernel: CONSOLE: txs frmid:0xafc4 txh frmid:0xafc4 lmem_idx:63wl1: wlc_dotxstatus: bail: tx status for invalid linkmem scb:00000000
Dec 26 21:30:18 rtaxbeast kernel: CONSOLE: txs frmid:0xb044 txh frmid:0xb044 lmem_idx:63dngl_finddev: slave 2 not found
Forget to mention that I already tried factory reset but problem reoccurring
Are you importing a saved backup config file after the factory reset? Are you checking the 'Initialize all setting...' check box too before resetting? Are you formatting the JFFS partition too? Are you 'blindly' using settings and options that may have worked on an older firmware/router?
Re-entered all settings from scratch and after reset. Jffs was reformatted and initially scripts and configs were not enabled.
I did enter all settings based on my settings of my ac3200, but I don’t have any specials settings (I think).
