RT-BE82U: SDN firewall generating MASQUERADE rule on br0 — breaks bridged VMs and containers
geekweaver
Possible missing `idx` check in firewall_sdn.c causing MASQUERADE on main LAN (br0) — breaks bridged VMs and containers​
Router Model: ASUS RT-BE82U
Firmware Version: 3.0.0.6.102_39254 (39254-gc155c5b_1531-g93455_BB0B)
Affected Branch: Potentially all ASUSWRT 5.0 / 3006.x branch models using the SDN firewall subsystem
Issue​
I did also post this over on ZenTalk forums but would like to post here too.
This is a new router that is replacing an older Orbi mesh. This is all transpired on the initial setup and replacement of my old router. While going through all of this, prior to finding this rule, I could swap back to my old Orbi and everything was perfect.
I've been troubleshooting an issue where inbound TCP connectivity to Proxmox VMs and Docker containers breaks after any firewall restart on my RT-BE82U. After digging into the iptables NAT table I found this rule being automatically generated:
Bash:
-A POSTROUTING -s 192.168.19.0/24 -d 192.168.19.0/24 -o br0 -j MASQUERADE
This appears to apply hairpin NAT to all traffic where source and destination are within the primary LAN subnet on br0. For users running Proxmox VMs, Docker containers, or any bridged virtual network interfaces, this breaks inbound TCP connectivity — destination hosts see the router's IP (192.168.19.1) as the source rather than the actual client, causing asymmetric routing and broken sessions.
Worth noting — ICMP (ping) continues to work fine, which makes this difficult to diagnose. Only stateful TCP connections fail, so it's easy to assume the network is healthy until you try to actually connect to something.
Trigger Conditions​
The rule is re-injected not just on reboot but on any event that triggers a firewall restart, including:
  • Router boot
  • WAN connect/reconnect
  • Any configuration save in the web UI that triggers firewall reload
  • AiProtection enable/disable
What I Found in the Source​
Looking at release/src/router/rc/firewall_sdn.c I noticed that the DoT block correctly uses an idx check to skip the main bridge (br0, idx=0):
C:
#ifdef RTCONFIG_DNSPRIVACY
if (pmtl->nw_t.idx)     //ignore br0
    // DoT DNS redirect logic
    fprintf(fp, "-A PREROUTING ...");
#endif
The NAT loopback block immediately following doesn't appear to have the same check.
Location: release/src/router/rc/firewall_sdn.c, approximately line 509 in the current main branch. Line numbers may vary by version — search for the comment // NAT lookback to locate the exact line.
C:
ip2class((char *)(pmtl->nw_t.addr), (char *)(pmtl->nw_t.netmask), sdn_subnet_class);
// NAT lookback  <-- possibly missing idx check here?
fprintf(fp, "-A POSTROUTING -s %s -d %s -o %s -j MASQUERADE\n",
        sdn_subnet_class, sdn_subnet_class, pmtl->nw_t.ifname);
When idx=0 (the main br0 interface), this generates a MASQUERADE rule for LAN-to-LAN traffic which doesn't seem intentional — though I may be missing context about why this was done this way.
Possible Fix​
If this is indeed an oversight, adding the same idx check used by the DoT block above might resolve it:
C:
// NAT lookback
This would ensure NAT loopback only applies to guest/IoT/VPN SDN profiles (idx > 0) and leaves the primary bridge untouched.
Verification​
Manually deleting the rule immediately restores full VM/container connectivity:
Bash:
iptables -t nat -D POSTROUTING -s 192.168.19.0/24 -d 192.168.19.0/24 -o br0 -j MASQUERADE
The rule returns on any firewall restart, confirming it is being procedurally generated rather than being a one-time misconfiguration.
Before fix — iptables POSTROUTING:
Chain POSTROUTING (policy ACCEPT 33 packets, 4922 bytes)
num   pkts bytes target     prot opt in     out     source                destination
1      691 53710 MASQUERADE  all  --  *      vlan201 ![public IP]        0.0.0.0/0
2     1598  148K MASQUERADE  all  --  *      br0     192.168.19.0/24    192.168.19.0/24
Before fix — netstat on client (192.168.19.122 connecting to VM at 192.168.19.6):
TCP    192.168.19.122:49250   192.168.19.6:53    FIN_WAIT_1
TCP    192.168.19.122:49666   192.168.19.6:53    FIN_WAIT_1
TCP    192.168.19.122:49667   192.168.19.6:53    FIN_WAIT_1
TCP    192.168.19.122:49747   192.168.19.6:53    ESTABLISHED
TCP    192.168.19.122:49919   192.168.19.6:53    FIN_WAIT_1
TCP    192.168.19.122:50382   192.168.19.6:53    FIN_WAIT_1
TCP    192.168.19.122:50855   192.168.19.6:443   ESTABLISHED
Multiple TCP connections stuck in FIN_WAIT_1 — sessions cannot complete teardown. Wireshark shows a flood of TCP retransmissions.
After fix — iptables POSTROUTING:
Chain POSTROUTING (policy ACCEPT 43 packets, 4755 bytes)
1      950 82286 MASQUERADE  all  --  *      vlan201 ![public IP]        0.0.0.0/0
After fix — netstat on client:
TCP    192.168.19.122:51783   192.168.19.6:53    TIME_WAIT
TCP    192.168.19.122:52022   192.168.19.6:8300  ESTABLISHED
TCP    192.168.19.122:52148   192.168.19.6:443   ESTABLISHED
TCP    192.168.19.122:52160   192.168.19.6:53    TIME_WAIT
TCP    192.168.19.122:52376   192.168.19.6:53    TIME_WAIT
Connections now completing normally — FIN_WAIT_1 replaced by clean TIME_WAIT states. Wireshark shows clean traffic with no retransmissions.
Hoping someone more familiar with the codebase can confirm whether this is intentional or an oversight.
Current Workaround​
For anyone hitting this in the meantime — a scheduled task running every few minutes on an always-on Linux host on your network:
Bash:
ssh [email protected] 'iptables -t nat -D POSTROUTING -s 192.168.19.0/24 -d 192.168.19.0/24 -o br0 -j MASQUERADE 2>/dev/null'
This can be added to cron or run as a Home Assistant shell_command on a schedule.
Has Anyone Else Seen This?​
I'm curious whether others have run into this, particularly those running:
  • Proxmox or any hypervisor with bridged VMs
  • Docker on a home server connected to an ASUS WiFi 7 router
  • NAS devices running Docker containers (Synology, TrueNAS, Unraid)
  • Any setup where devices have virtual MAC addresses behind a Linux bridge
The symptom is easy to miss — ping works fine but TCP connections to your VMs or containers fail or time out, and everything works perfectly if you switch to a different router. If you've experienced this and assumed it was a misconfiguration on your server side, it may actually be this rule.
Running iptables -t nat -L POSTROUTING -n -v on your router will show the rule if it's present.
I don’t know why lan-to-lan traffic would even pass through the firewall. 192.168.19.0/24 is the main lan subnet?
Yes. Right now, that's the only subnet I have, to keep it simple.
I am also perplexed by this. I have, essentially, a core (dumb) switch that is uplinked to this router with edge (dumb) switches that connec to the core. I would have expected wlan-to-lan traffic to obviously pass through this, but lan-to-lan to stay at the switch. What's even stranger is that from my proxmox host (hard wired), it couldn't do proper tcp handshake with a VM running on itself. This is not a complex network. As soon as I remove this MASQUERADE rule, everything opens up. I need to dig more into it and sniff some more traffic. I have been doing IT professionally for a LONG time and this has to be one of the strangest things I have seen.
