AX86U Pro - why two MU-MIMO options?
PeterPiper82
Greetings community! AX-86U Pro owner here. Under the professional WiFi settings menu (5GHz band), I noticed there are two MU-MIMO settings:
1. Multi-User MIMO
2. OFDMA / MU-MIMO
The first one has a simple Enable/Disable toggle.
For the second one, MU-MIMO can only be enabled if OFDMA is also enabled as both are combined under one single drop-down option.
I have some questions:
1. Why are there two MU-MIMO options? Is the first one for WiFi5 (802.11ac) clients and the other one for WiFi6 (802.11ax) clients exclusively?
2. Assuming the answer to the second part of
my first question above is ‘yes’, how
do I enable MU-MIMO (for both WiFi5 and WiFi6 clients) while keeping OFDMA disabled?
