Ax86U - slow reconnection to iphone
Andy Sedg
Just purchased this router to replace BT smart hub 2 & noticed an issue related to my iPhone 11 connecting to the internet after going out & disconnecting. On return home the iphone connects to the router but has no internet connection for a few minutes. Any idea what might be the problem & how to solve it. Thanks
No issues with iPhone/iPods here. Must admit that they are older units.
Newer iPhones randomize their MAC. You might turn that feature off.
Router WIFI settings: 2.4 GHz at 20 MHz on a fixed channel (1, 6 or 11), 5 GHz at 160 MHz on channel 36 (recommend not to use DFS channels), WPA2/WPA3, disable Airtime Fairness and Universal Beamforming for both bands. Use Dual Band Smart Connect.
Here are my Wi-fi settings
