Backup strategy question - RAID or just copy?
nikleb
This is not really a NAS question. I just figured it might fit here.
I am planning to install a large drive (i.e. 3TB) into an older Dell T100 server that is running Win2003. I would like to keep a backup drive (second 3TB drive) for the most part in a safe location. I am planning to use a Startech hotswap drawer for the backup drive (DRW115SATBK).
My question: what is the best strategy to keep a backup/mirror of the main drive? RAID or simply do a copy of the drive every so often?
If u want to keep back up copy in a safe place, best is to do a copy of yr master. If u intend to use NAS, get a single drive NAS as file server then use normal external hdd as yr safe copy.
Sent from my GT-I9305 using Tapatalk 2
In this case I don't need a RAID controller. However, I am looking for some input for a good sata controller that really supports hotswap. I did not get lucky under Win2003. Is an Adpatec a good choice?
Look at latest Antec 2 bay enclosure. It does USB3 and eSATA. I use one with Synology DS213+ Antec can work as Raid 0, 1 or two separate drives. I can plug it into DS using either port or Plug it into my PC using USB3 connection. Not made for hot swap tho.
Pegasus9 Need Cross NAS BackUp Solution General NAS Discussion 4
R Question on NAS setup General NAS Discussion 4
