Basic AiMesh questions
Scott Kaforey
Currently I have one AC88U providing wireless for my house. I have 2 very cheap TP-Link routers that I also use, one connected wirelessly to provide a hardwired connection for a security camera, and the other one wired acting as an AP.
I'm thinking of adding one or 2 mesh clients, but I'm wondering how it works. Currently my AC88 is using a custom dnsmasq.conf file for static dhcp as I like to have a clean, organized network. There are around 60 entries in there.
1) If I add nodes, will the clients connected to the nodes use get IP addresses from my main router, or the node itself?
2) I'm assuming this is an obvious one, but will devices connected to one node be able to see/connect to other devices on different nodes transparently?
Thank you in advance!
Yes to both questions
As far as I can tell the address assignment, routing, etc are the same as with an ordinary access point -- that is, the main router carries the load. I will be interested to hear of how the stability and performance of your mesh network compare to the access point version you now have.
