psychopomp1
In my home, i have wifi 7 access points in every room (TP Link RE655BE) and where possible, I try to connect every wifi 6E/7 client to the 6ghz band on the AP since usually there is clear line of sight to each AP. On all RE655BE units i have selected 69 (PSC) channel on the 6ghz band and no major issues, but just wondering if there's an ideal channel to use? I am offered tons of channels between 1-93 though only channels 5-21-37-53-69-85 are PSC. 6ghz channel width is set to auto (20/40/80/160/320 Mhz)
Cheers
Cheers
