PR3MIUM
And another Seller is on the WiFi7 Train before 2024 (Q1 2023)
WiFi7 Gaming Router:
"Maximum wireless signal rates are the physical rates derived from IEEE Standard 802.11 specifications.
Actual wireless data throughput, wireless coverage, and connected devices are not guaranteed and will vary as a result of network conditions,
client limitations, and environmental factors, including building materials, obstacles, volume and density of traffic, and client location.
‡Use of Wi-Fi 7 (802.11be), Wi-Fi 6 (802.11ax), and features including MLO, 320 MHz Bandwidth,
4K-QAM, Multi-RUs, OFDMA, and MU-MIMO requires clients to also support the corresponding features. Not all 320 MHz channels may be available in the 6 GHz band in some regions/countries due to regulatory restrictions.
△The 320 MHz bandwidth is only available on the 6 GHz band and may be unavailable in some regions/countries due to regulatory restrictions. The double channel width and speed refer to 320 MHz compared to 160 MHz for Wi-Fi 6 routers.
*HomeShield includes the Free Basic Plan. Fees apply for the Pro Plan. Visit tp-link.com/homeshield for more information
**This router may not support all the mandatory features as ratified in the IEEE 802.11be specification."
Source:
BE19000 Tri-Band Wi-Fi 7 Gaming Router
Archer GE800 is an innovative WiFi gaming router with a brand-new design. With up to 19 Gbps tri-band Wi-Fi, two 10G ports, two 2.5G ports, abundant gaming acceleration functions, GE800 boosts gaming traffic, stabilizes connections, and reduces latency to ensure your gaming stays immersive.
www.tp-link.com
Source:
TP-Link Wi-Fi 7 Routers Are Coming in 2023, Before Wi-Fi 7 Even Gets Here
Wi-Fi's next generation isn't likely to make its debut until 2024, but that isn't stopping TP-Link.
www.cnet.com
TP-Link
What is the unparalleled network experience? TP-Link will open up a brand new era of home and enterprise networks by carrying the expected WiFi 7 products in 2022.
www.tp-link.com
What is WiFi 7? How Does WiFi 7 Work? | WiFi 7 Routers | TP-Link
WiFi 7 (Wi-Fi 7), the 7th generation of Wi-Fi, is built for extremely high throughput. WiFi 7 works across all three bands (2.4 GHz, 5 GHz, and 6 GHz) to fully utilize spectrum resources. Here is everything you need to know about it—what WiFi 7 is, why we need WiFi 7, and how it works and what...
www.tp-link.com
