Best AC access point or router for mobile devices
paraplu
Would be great to show a graph comparing range/speed performance between ALL AC accespoint (or wireless routers) and simple 2 antenna AC devices. Which is the current state of things.
Currently we are forced to compare by AC type. Makes comparing not so easy.
In device reviews there are graphs that show that but i dont think you could make a chart to compare this unless you want to compare averages which is not a good idea as some wireless routers do not perform linearly different between the ranges.
