BIP, AKM suite auth type 2
snbdora
Hello,
I've been getting this message repeatedly in "message" on WRT1200ac with the latest stock firmware. This is happening for the 2 Wifi clients ( on the 5GHz band ) I've - Lenovo T400 with Intel 5350 adapter and Fire TV 2. Apparently a lot more of this message with Intel 5350 than for the Fire TV. Whenever it happens, it just would cut of the clients off the network for a while but Does anyone know what this message indicates and know what could be the problem?
Sta does not support BIP, AKM suite auth type 2
Goes to 802.11w protected broadcast/multicast frames...
On the WRT, ensure that you are set for WPA2 only, not WPA1/WAP2 mixed... if so, change it..
On the clients, forget the connection (delete it, whatever) and rejoin the AP with a new Wireless Profile.
Things should work better then..
On the router, I've WPA2 only setup. I recreated the wireless profile but no avail. Using Access connection with Windows 7 wlan autoconfig or just using the Windows wlan autoconfig alone would still pop up the warning. I couldn't find a way to use the Access connection independently of the Windows wlan autoconfig.
