^Tripper^
Hi folks. I’m running Merlin’s 384.14 on an 86U with Skynet and Diversion and pixelserv. Wondering if there’s a way to block off a whole TLD?
From what I can tell, the only option is to create a ‘dnsmasq.conf.add’ as Skynet and Diversion doesn’t allow something as drastic as blocking a whole TLD (probably with good reason).. unless I’m missing something obvious.
I’ve tried creating the file in jffs- config with the following;
Now that seems to work but DNS lookups have slowed down; pages take longer to load. I’ve also tried using pixelserv’s address and that seems to work the same.
From a purely technical standpoint, what’s the best way to do this?
Thank you!!
address=/.xyz/0.0.0.0
address=/.pro/0.0.0.0
Thank you!!
