XIII
Part of the Furniture
How to check this?For some reason both are running at the same time.
Reason for asking: I noticed I also have both S77ntpd and S77chronyd in /opt/etc/init.d and might have the same issue as you?
Run the following command in an SSH window:How to check this?
top -b -n 1 | grep -E "ntpd|chronyd|timeserverd" | grep -v grep
ntpmerlin develop
Thanks @Martinski. I do suspect it was somehow installed by the recent Entware update.
Curious if this started happening with the latest Entware update, that’s about the timeframe it did for me, ...
ntpd or chronyd) has not been overwritten or modified (e.g. via Entware package updates). If the service script doesn't match as expected, the code will re-download the ntpMerlin-specific script, replace the existing version, and restart the time server. It will also remove the additional time server script (if found).Thanks for the tips, but I think the simplest solution would be to double-check the existing Entware service scripts and replace or remove as needed (see above). At worst, there's a 10-minute gap between checks during which the wrong service scripts may exist simultaneously; however, the situation will be corrected automatically, and most users won't even notice.One behavior i have notice when running ntpmerlin is that it still leaves the entware packages installed even when just switching between the two. This creates a bad behavior when users go to update and upgrade their entware repositories, it automatically reinstalls the init.d scripts for the unused ntp service because the package is still technically listed as one of entwares installed packages. So lets say we are using chronyd, but ntpd is still listed as an installed entware package even though we are not using it with ntpmerlin. Entware will recreate the init.d script upon upgrading entware repository of installed packages.
That is great for people who run ntpMerlin, but what about when they uninstall ntpMerlin. Surely you have a cleanup to remove the unused binary.I've made changes in the script to double-check that the selected NTP service script that's installed by ntpMerlin (forntpdorchronyd) has not been overwritten or modified (e.g. via Entware package updates). If the service script doesn't match as expected, the code will re-download the ntpMerlin-specific script, replace the existing version, and restart the time server. It will also remove the additional time server script (if found).
These checks are performed at startup following a reboot, every time the NTP server is started or restarted, and every 10 minutes via the pre-existing cron job that generates time server stats.
The latest 'develop' branch version tag is v3.4.10_25073100.
Example:
Thanks for the tips, but I think the simplest solution would be to double-check the existing Entware service scripts and replace or remove as needed (see above). At worst, there's a 10-minute gap between checks during which the wrong service scripts may exist simultaneously; however, the situation will be corrected automatically, and most users won't even notice.![]()
Of course!⁹
Looks like I am good?Run the following command in an SSH window:
Bash:top -b -n 1 | grep -E "ntpd|chronyd|timeserverd" | grep -v grep
➜ top -b -n 1 | grep -E "ntpd|chronyd|timeserverd" | grep -v grep
23059 1 nobody S 79884 7.8 2 0.0 chronyd -r -u nobody -f /opt/share/ntpmerlin.d/chrony.conf
23032 1 me S 3324 0.3 2 0.0 {timeserverd} /bin/sh /opt/bin/timeserverd S77chronyd
➜ cat /opt/etc/init.d/S77ntpd
#!/bin/sh
[ -f /opt/etc/config/ntpd ] && . /opt/etc/config/ntpd
ENABLED=yes
PROCS=ntpd
ARGS="-c /opt/etc/ntp.conf -p /opt/var/run/ntpd.pid -f /opt/var/spool/ntp/ntp.drift -s /opt/var/spool/ntp -k /opt/etc/ntp -g $OPTIONS"
PREARGS=""
DESC=$PROCS
PATH=/opt/sbin:/opt/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
. /opt/etc/init.d/rc.func
Yep, looks good.Looks like I am good?
Code:➜ top -b -n 1 | grep -E "ntpd|chronyd|timeserverd" | grep -v grep 23059 1 nobody S 79884 7.8 2 0.0 chronyd -r -u nobody -f /opt/share/ntpmerlin.d/chrony.conf 23032 1 me S 3324 0.3 2 0.0 {timeserverd} /bin/sh /opt/bin/timeserverd S77chronyd
However, I don’t understand why this doesn’t start ntpd:
Code:➜ cat /opt/etc/init.d/S77ntpd #!/bin/sh [ -f /opt/etc/config/ntpd ] && . /opt/etc/config/ntpd ENABLED=yes PROCS=ntpd ARGS="-c /opt/etc/ntp.conf -p /opt/var/run/ntpd.pid -f /opt/var/spool/ntp/ntp.drift -s /opt/var/spool/ntp -k /opt/etc/ntp -g $OPTIONS" PREARGS="" DESC=$PROCS PATH=/opt/sbin:/opt/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin . /opt/etc/init.d/rc.func
Indeed; after the upgrade from Beta 2 to Beta 3:If you reboot the router, or if you simply remove the USB-attached disk and then plug it back in, it will trigger a restart of the Entware services.
8367 1 nobody S 85792 8.3 0 0.0 chronyd -r -u nobody -f /opt/share/ntpmerlin.d/chrony.conf
8353 1 me S 76084 7.4 2 0.0 ntpd -c /opt/etc/ntp.conf -p /opt/var/run/ntpd.pid -f /opt/var/spool/ntp/ntp.drift -s /opt/var/spool/ntp -k /opt/etc/ntp -g -l /opt/var/log/ntp.log
8299 1 me S 3324 0.3 2 0.0 {timeserverd} /bin/sh /opt/bin/timeserverd S77chronyd
On mine it looks like it actually does start ntpd but then exits because chrony is already listening on port 123However, I don’t understand why this doesn’t start ntpd:
30 Jul 00:02:48 ntpd[6805]: Listen and drop on 0 v6wildcard [::]:123
30 Jul 00:02:48 ntpd[6805]: unable to bind to wildcard address 0.0.0.0 - another process may be running - EXITING
30 Jul 00:02:48 ntpd[6787]: daemon child exited with code 1
We use essential cookies to make this site work, and optional cookies to enhance your experience.
