BQ16 Pro jumping between mesh loses internet on devices. Suggestions?
jucytec
Coming from 3 x XT8 in my house, about 3500 SqFt, the setup worked but wanted to get faster wifi speeds transferring large files. So I switched XT8 with 2 x BQ16 Pro.
All is working well, my router itself is not losing WAN connection like others are reporting, but I am seeing my wifi devices themselves loosing internet moving throughout the house.
If i had to guess it's right around places where devices would switch from 1 node to the other node. toggling the connection will bring the internet back, but it does get annoying since it happens multiple times a day.
The entire house is running on 2.5Gb switch for wired connections in each rooms, the connection between the mesh is 10Gb. I'm not using wireless backhaul, all wired, no issues on wired devices, or devices that are stationary. It's only phones that move around the house which tends to have this issue.
Anyone else experiencing something similar? Asus has been pretty steadily pushing out FW every 2 months, but seems like no movement since Oct. I wanted to tweak roaming settings perhaps but couldn't figure out the exact setting yet. Looking for any suggestions.
