BTRFS Support?
bryan_moore
I've been running merlin for a while on my AX86U and my ancient Dell Inspiron, to which I connected by btrfs-formatted usb drive for use with jellyfin, just died; so, I tried to "plug-and-play" with my router instead but can't seem to mount and/or use the mediaserver on my Roku tv.
Any suggestions for where I can find some troubleshooting info? Thanks, in-advance!
If you have Entware installed on your router it has a package you could try installing, btrfs-progs. I've never used it though.
Thanks for that... I don't currently have entware installed and just figured it would be easier/simpler to just resize my btrfs partition down, create an ext4 partition on the same disk, copy over my files, and then resize the ext4 partition. Odd how that's likely "simpler." ;-)
